Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Timber Frame Setup and Take Down  (Read 381 times)
Offline Flathill
  • Member*
« on: January 13, 2012, 09:12:00 am »
I want to build a small timber frame building in my yard and then dismantle it and relocate it to my outback property. Do I put wooden pegs in it and later drive them out or drill them out or use removable steel pins.
What is normally done when a frame is assembled with plans for it to be taken to another location ?           Flathill
Offline beenthere
  • EIEIO
Re: Timber Frame Setup and Take Down
« Reply #1 on: January 13, 2012, 09:14:31 am »
Welcome to the Forum.
Jim just posted about how to do that.
http://www.forestryforum.com/board/index.php/topic,55412.msg801108.html#msg801108
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #2 on: January 13, 2012, 04:24:43 pm »
Flathill:
We don't bore the holes usually until just before we put it together for the final time, if we're going to take some time to cut the joints.
If we're going to put it right together then we only bore the mortise holes first, put the tenon in and check the measurements. If they are off we trim and adjust the shoulders of the pieces until all is right.
Then we poke the bit into the mortise peg hole and then draw bore the tenon hole.
Then we put it together and the peg pulls the joint tight.
If you're going to put it all together in your yard, I'd bore the holes, draw bore the tenons and then don't push the pegs in very far just enough to hold it together. Then using a "peg pusher" you push the pegs back out to disassemble it.
Then move it to where you're going to put it together.
When it's where it's going to stay, then drive the pegs all the way in.
Never re-bore holes, or bore out pegs.
You can look at the frame on my webpage and you'll see the pegs sticking way out.
This is so I can disassemble the frame and move it to where it will be erected at the customer's location.
You need to have nice tapered pegs with small points and a good peg pusher.
My peg pusher is a brass dowel, just a bit smaller then the peg hole size so that it catches the peg point cleanly and doesn't get wedged in beside it.
Hope that helps.
Jim Rogers
Offline Flathill
  • Member*
« Reply #3 on: January 14, 2012, 01:31:00 pm »
Thanks Jim,  So build the timber frame in my yard and drill the peg holes but do not put the wooden pegs in very far, but enough to hold the building frame together. Then use a brass peg pusher to push the pegs back out and disassembe the frame for loading on to a truck for transporting.
Sounds good ! I know there are more details but I just needed the basic plan so the frame wouldn't be too difficult to take apart.    Flathill
Saw Anywhere!
