Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Wavy boards  (Read 833 times)
Online Bogue Chitto
Wavy boards
« on: January 12, 2012, 04:16:05 pm »
Since I ordered new blades my boards are all wavy.  Is there a way to look at the blades and tell if they are bad or set wrong?
Offline 1938farmall
  • Uff-da
Re: Wavy boards
« Reply #1 on: January 12, 2012, 04:43:19 pm »
has the down pressure on your guides changed?  should be about 1/4".  just a guess.  al
aka oldnorskie
Online Bogue Chitto
Re: Wavy boards
« Reply #2 on: January 12, 2012, 04:53:01 pm »
Last month every thing has been readjusted to factory specs. I am pretty sure it is the blades because older blades cut just fine so far.
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
Re: Wavy boards
« Reply #3 on: January 12, 2012, 04:57:09 pm »
Did you get the same kind of blades? Same thickness, pitch and manufacturer? Are you cutting the same species of wood as you were before?
Online Bogue Chitto
Re: Wavy boards
« Reply #4 on: January 12, 2012, 05:02:58 pm »
Yes, Pine logs.  This happens mainly on logs over 15".  I will start say at 10" from the deck and it will come out at the other end 9" with waves in between.
Offline Chuck White
  • Sawing Mobile since 2005
Re: Wavy boards
« Reply #5 on: January 12, 2012, 05:11:38 pm »
Sure sounds like something is not aligned!
Is the blade square with the bed?
Almost sounds like the bunks are not aligned with each other.  Re: 10 inch entrance and 9 inch exit!
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Online Bogue Chitto
Re: Wavy boards
« Reply #6 on: January 12, 2012, 05:22:42 pm »
Bed is square. -- On these new blades, as I watch the blade while traveling down the log it will begin to move down binding on the engine. It will not do it on my older blades that I have had sharpened.  I think that the new blades are set wrong. Is there a way to tell if the tooth set is wrong.  I don't have a gauge or any tool to check tooth angle.
Offline pineywoods
Re: Wavy boards
« Reply #7 on: January 12, 2012, 05:26:55 pm »
Sounds like not enough set in the blade. Cutting pine, You need a bunch, 20 thou minimum, 25 or 30 better. Could also be just plain DULL and you are pushing the blade past it's capability.
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline beenthere
  • EIEIO
Re: Wavy boards
« Reply #8 on: January 12, 2012, 05:29:30 pm »
Also, are the teeth on the inside contacting the roller guide such that it is removing the set on half the teeth?
Best to get a gauge to check the set. It will come in handy.
Offline ely
Re: Wavy boards
« Reply #9 on: January 12, 2012, 05:29:45 pm »
i have got bad bands out of the box before, its rare but it has happened. i can look at a band and tell if it has enough set to suit my needs... but then i have a setter and have looked at alot of them.
without being there it would be hard for me to form an opinion.
Online Bogue Chitto
Re: Wavy boards
« Reply #10 on: January 12, 2012, 05:31:41 pm »
Sawing for 6yrs.  at same speed as always.
Offline ely
Re: Wavy boards
« Reply #11 on: January 12, 2012, 05:33:58 pm »
probably not with those bands though....just sayin. things change for no reason at all, you should know that from running a sawmill. ;D
Offline ladylake
Re: Wavy boards
« Reply #12 on: January 12, 2012, 05:39:53 pm »
 Just hold the bands up to good light and look at them from the side, you'll see the set or lack of it.  Compare your new and old blades.  Did you get the same brand, hook angle, thickness?   Have you tried your old blades after having trouble with your new ones?     Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline paul case
Re: Wavy boards
« Reply #13 on: January 12, 2012, 07:55:40 pm »
Sure you can check the set on band teeth. I use a caliper micrometer. Hold one of the jaws againsst the back of the band flat( body) and the other against the tip of the set tooth. it should read band thickness plus set on my blades which are .042 I shoot for a set of about .070. PC
EZ Boardwalk and WM 94 LT40 hd
pc
Offline bandmiller2
Re: Wavy boards
« Reply #14 on: January 12, 2012, 08:49:11 pm »
Chitto,I'd put one of your old bands on and try it,if it cuts fine the new bands would be suspect.If you don't have any measuring tools look down on the band in good light the set tooth should be offset about half the thickness of the band body.Sounds like you don't have even set on one side. Frank C.
Online Bogue Chitto
Re: Wavy boards
« Reply #15 on: January 12, 2012, 09:32:09 pm »
Looks like every other tooth is set to the same side.
Offline beenthere
  • EIEIO
Re: Wavy boards
« Reply #16 on: January 12, 2012, 09:34:29 pm »
Think you found the problem. :)
Now to decide when it happened, and if on your end, how it happened.
Online Bogue Chitto
Re: Wavy boards
« Reply #17 on: January 12, 2012, 09:37:45 pm »
New one out of the box never used.  I will send the blades back.  Thank You every one for your help.  This is a very good sight with good people.  Thank you again.
Offline Magicman
  • Knothole Sawmill, LLC
Re: Wavy boards
« Reply #18 on: January 12, 2012, 09:49:28 pm »
Now Bogue Chitto, Welcome to the Forestry Forum.  How about a short introduction about yourself and your operation.  I live within a mile of the Bogue Chitto River, but it is quite small here.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Online Bogue Chitto
Re: Wavy boards
« Reply #19 on: January 12, 2012, 10:05:00 pm »
Thank you, Mr. Magic man.  I live north of the small town of Franklinton La. on the Bogue Chitto river.  (South of Tylertown Ms.)  We grow timber and run a Blue berry farm.  When I am not working I am sawing or deer hunting with my sons.
I mostly saw at home.  ( My logs or customers bring me theirs.)
Saw Anywhere!
