Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: What type of log is this?  (Read 2994 times)
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
Re: What type of log is this?
« Reply #40 on: January 13, 2012, 10:13:12 am »
Do you have a picture of a board? Even Basswood and Aspen lumber will look very similar until you see the knots in the lumber.  Basswood has knots with very distinct defined edges, where as aspen knots will usually have color spreading from the knot edges which are not nearly as defined.
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #41 on: January 13, 2012, 10:16:52 am »
That's OK dodgy because I've seen a person that should know, confuse balsam poplar for red oak. And had the log(s) right there to look at. And swear up and down it was red oak. And cut them where no red oak was present down on a wet flood plain. You just gotta walk away.   ;D
Dirty Harry
Offline Jeff
« Reply #42 on: January 13, 2012, 11:30:11 am »
I've also seen a high school shop teacher confuse balsam poplar for red oak. One of my cousins. I went to the old farm and he had a couple sections of short 4 foot logs in his truck. He was going to take the "Red Oak" home and cut it into boards on the shop band saw for a personal project.
Offline WDH
  • April 1998 - August 2008
« Reply #43 on: January 13, 2012, 09:40:56 pm »
All the southern boys are sitting this one out, I see :D. We don't have true poplar around here. Just yellow-poplar (aka tuliptree). We do have basswood in limited areas, but the bark looks a lot different from your northern stuff. I won't be of much help on this thread. :)
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline Gary_C
  • Sunrise on the Prairie
« Reply #44 on: January 13, 2012, 10:01:18 pm »
Jeff is right on the money. That's Aspen.
Aspen has so many different looks to it's bark, it can fool you. But that deeply furrowed look to the lower part of the tree is common. Sometimes you have to look up to the top of the tree to be sure what it is, but after seeing a lot of Aspen go down in front of my harvester, I know it's aspen. And definately not Basswood.
Offline Gary_C
« Reply #45 on: January 13, 2012, 10:08:11 pm »
This is what our aspen looks like.
Wow, that one wins a prize. The Lyle Lovett of aspen trees.
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #46 on: January 14, 2012, 05:19:39 am »
Yeah the second one is a nasty widow maker with lot a lateral limbs. It was over mature and full of conk. I wouldn't take a saw anywhere near that thing. ;D The picture was for the bark, not for the beauty. :D It's also over 30" dbh. The first was 26 inches dbh as I recall.
Aspen logs here that are up to 14 or 18 inches have smooth green/gray with some white sections or pinkish hue bark beyond 5 or 6 feet of the but. Like this. Unless its the white barked ones that never seem to grow much on higher elevation. This is at the point where the bark is starting to separate into ridges. This tree is around 14" and probably 35 years old. I have a 10" in the back yard and the bark is more green at 25 years of age.
That tree has enough logs from it that you would see some of the traits on up the tree. I don't see it, so can't agree to aspen. ;)
I don't consider these junk when you get as much for pulp as veneer for them. That's why no one bothers to separate it because of the extra handling costs for nothing.
I think you'll find that the variance you see in the bark is hybridization and between species of poplar. I've been to Jeff property I saw aspen just like what I see here in NB. Not even a second guess. I also see it across northern Ontario. ;)
Dirty Harry
Offline Jeff
« Reply #47 on: January 15, 2012, 05:36:18 pm »
The aspen in the U.P. on my property, would not be typical to what we see at this latitude. Although we have some that looks like that, is can have a very different appearance from site to site. Some can even look like white birch from a distance.  It would be rare for us to confuse a basswood log with Aspen. Ash, yes. Basswood looks quite a bit like ash in log form with the bark on. New yard guys at the mill would always confuse it.
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #48 on: January 15, 2012, 05:56:29 pm »
Yes, as I said your aspen grows like here. We have those white barked aspen that look like white birch to. But you would still not confuse it, or I wouldn't. ;)
As far as basswood goes it grows with white ash and hard maple up here and I wouldn't confuse it for ash, but instead some folks confuse it for hard maple. My father for one. ;)
I think it might just be the color or photography angle in the pictures, but sure looks like basswood bark.
MM has a bunch of photos of aspen in CO from his hunting excursions and they have the white bark.
Dirty Harry
Offline Dale Hatfield
  • A plan is a start to a great ending
« Reply #49 on: January 15, 2012, 07:54:35 pm »
No doubt Its aspen.  We  often see 2 kinds of aspen smooth wood and fuzzy wood.  when ya buck a log you will see what is fuzzy or smooth.
Funny is the fuzzy one will often hold a hinge better than the smooth wood. But neither will hold much for side lean.
Jeff is spot on I have seen everything he has said in aspen as well.
Chainsaw Carver
Offline Dana
    • Green Leaf Farms
« Reply #50 on: January 16, 2012, 06:10:06 am »
I thought we had the answer two pages ago so I didn't reply. Since the debate is still on I say it's Aspen or what we locally call popple.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #51 on: January 17, 2012, 07:45:02 am »
 SD is having trouble acknowledging that his books don't have the answer... It's OK Bill, every once in a while one misses and gets a strike , you've hit so many out of the park this one we"ll let pass  ;D
  It has poplar written all over it.  The fact that it is a year old on the ground is deceiving. Sorry Bill... it's poplar , I can't tell ya what kind of poplar aint that smart but its in that  family tree.  :)
   Marcel
Offline 1crowfarm
« Reply #52 on: January 17, 2012, 08:40:30 am »
Hello folks I plan on sawing tomorrow god willing I have three or four Poplar logs on the log deck to saw before I saw these ? logs up I will take lots of pictures and post them on here .I'am thinking that these logs are Aspen now from the last picture that was posted on here.
Hopefully we can solve this mystery with some pictures of the boards cut from this logs  ;D
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #53 on: January 17, 2012, 12:31:00 pm »
Marcel it was based purely on experience. Never saw aspen with basswood bark before. ;D What I showed for aspen is what we got, simple as that. If I'm wrong that's fine, never bothered me before. ;) Anyone that would get worked up over a darn tree has some issues. ;)
Dirty Harry
Offline MapleNut
« Reply #54 on: January 17, 2012, 01:50:31 pm »
It is aspen...you can tell by the smell!! ;)
2005 WM LT40HDG28, 5500 IRON MULE, 272,262,046,&P70, CANT HOOK & A PIC!
Offline Jeff
« Reply #55 on: January 17, 2012, 02:00:54 pm »
We are now in agreement! Because on the other hand, I've never saw aspen basswood with basswood aspen bark before.  ;)
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #56 on: January 17, 2012, 02:52:38 pm »
Yeah, what do they call that? cancelled reciprication or something? Well they should anyway. :D
Dirty Harry
Offline WDH
« Reply #57 on: January 17, 2012, 08:01:47 pm »
You are the Yin and he is the Yang  :).
Offline LeeB
« Reply #58 on: January 17, 2012, 08:16:42 pm »
Yep, a couple of ying yangs.  :D
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 1966 Chevy C60 w/ dump bed.
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #59 on: January 17, 2012, 08:17:54 pm »
Now that we've resolved that, what's next? ;D
Dirty Harry
Saw Anywhere!
