Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Homemade Band Guide Idea - Whatcha think?  (Read 1094 times)
Offline rwthom279
  • Work Smarter, Not Harder
Re: Homemade Band Guide Idea - Whatcha think?
« Reply #20 on: January 12, 2012, 07:16:39 pm »
Ah Ha, this might be a solution, plus it may address the concerns of myself and others.  Waiting on dimensional info to see if the wall is thick enough - 1750# cap.  7600 rpm @ 5000 fpm bandspeed.  But oil for lube and no "trailer" weight on it that would surely increase allowable speed because of a drastic reduction in friction/heat...right?  Fill 'er w/ 90w synthetic and let'er rip???
Winning an arguement isn't everything, as long as you are heard and understood - W.S.
Offline 5quarter
« Reply #21 on: January 12, 2012, 08:23:21 pm »
Thats the spirit!   8) 8)
Offline GF
    • Twisted Oak Sawmill
« Reply #22 on: January 12, 2012, 08:29:48 pm »
I tried using three bearing idea for awhile, seems like the bearing locked up very often and then had to replace.   I ended up by the roller guides from Cooks and machined everything else, that was the best move I did.  Replaced the inner bearing on them a couple of times.   A couple of months ago took them off and trued them up in the lathe, the wear on them caused a small taper to the front, now they are back on and hopefully good for another 4 years.
Home built bandsaw sawmill with 31hp v-twin, Cooks Catclaw Sharpener, Cooks dual tooth setter, John Deere tractor, 35 ton splitter, and home built firewood processor.
Offline bandmiller2
« Reply #23 on: January 12, 2012, 08:41:08 pm »
RW, how often do you have to change the three bearing setup your using now.?  Those sealed ball bearings are the same as used in the "store bought"band guides.Excessive wear on the band rear bearing could indicate its too close to the band, should be a gap when band is running free.Try your trailer hub idea,you could always go back to what you have now or to the cook system if it doesn't work out as expected. Frank C.
Offline ladylake
« Reply #24 on: January 13, 2012, 05:16:11 am »
 I'd give Franks setup a try but would run 2-1/2 to 3"  OD  bearings which would turn slower and not bend the band as much.    Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline buildthisfixthat
« Reply #25 on: January 13, 2012, 06:43:47 pm »
isure that hub idea will work however !!! machine it down to the size needed may be a challange ?also the weight ,balance is critical turning resistance may be a problem ,
shop built bandsaw mill
Offline ladylake
« Reply #26 on: January 14, 2012, 05:05:41 am »
 I'd think the metal is way to soft, would need a hardened collor to work for long.   Steve
Offline rwthom279
« Reply #27 on: January 21, 2012, 12:15:53 pm »
Well, after alot of "reasearch", if it can be called so, I think there is an answer - Yes and No.  If I had smaller mill what ran a slower blade speed and manually fed, Yes.  A fella actually tried this with a greasable hub and had limited success on a homemade mill.  Limiting factors where temp. and feed rate.  Warm enough and watched what the blade was doing, ensured a good result. If someone used the oil lubed hub and no hardened surfaces it might be feasable for them...especially DIY mills.
As mentioned above about RPM/FPM, hardened flange, maybe hardened collar, etc.  I believe it would work, but considering parts, labor, machine work, etc. not to mention excessive RPM's, hydro feed,  I'm gonna take the advice of a few and just go with the "Cooks" type.  Maybe more money now, but less down the road.
So I reckon I'll have to save my pennies for awhile, and not throw good money after possible bad.  Thanks for your input!!
Offline bandmiller2
« Reply #28 on: January 22, 2012, 07:31:46 am »
RW,I think you made a good decision sometimes we just have to suck it up and spend the coins, it hurts though.Some day I may convert,but for now I hate to mess with something thats working well. Frank C.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #29 on: January 22, 2012, 07:38:20 am »
Not to worry.  I am sending RW a couple of blade guides that I have.  They still have plenty of groove and I think that they will serve him well.   :)
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline rwthom279
« Reply #30 on: January 22, 2012, 11:05:35 am »
Well, I look at it this way...may not have worked for me, but someone else may be able to utilize the idea or perhaps build upon it.  Thank You again MM.  At least by having the guides themselves, I can built the rest to match.  Then replacement will be simple, not a complicated issue of ordering, machine work, etc.
Bandmiller, you're right...boils down to: money now, or more money later.  And that goes for more than people think.  Save a penny now, spend a dollar doing it over right.  But thats also how we learn!!! :D
Thanks again everyone!!
Saw Anywhere!
