Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Do hydraulic hoses rupture with age?  (Read 907 times)
Online barbender
Re: Do hydraulic hoses rupture with age?
« Reply #20 on: January 10, 2012, 10:30:12 am »
BTW, my experience is where the hose flexes is where it fails, especially if it is a tight bend.
I just want to run my mill
Offline pinehillstacker
« Reply #21 on: January 10, 2012, 01:21:45 pm »
Gary_C, Goodyear did get back into hydraulic hose.  My dad's hydraulics business is a distributor of Goodyear hose.  They make a quality product; he used to use NRP Jones, but he liked the Goodyear quality better, plus they're made in the USA, so he switched to them.  Also, like MagicMan said, the hose protectors work very well, are cheap, and come in all sizes.  We use them on all our equipment on the farm.  As far as around here in SW PA goes, you can get a good deal on hydraulic hoses if you take it to the right shop.  Some of them have the "I got it, and you need it" attitude, and that is where you will get into big $$$.  My dad's business can normally make a hose for somebody at half his competitors' prices, and still turn a profit.
Offline Brucer
  • The Kootenay Sawyer
« Reply #22 on: January 10, 2012, 06:08:01 pm »
I had the same hose fail on my mill when it was only a year old. Turns out the fitting on the cylinder was at a bad angle and the hose kinked every time the clamp was fully retracted.
I had another hose fail inside the frame tube!. Couldn't figure out why I was losing fluid until it started running out one of the holes in the side. I found the cause when I opened up the hydraulic box and found a pack rat next made out of the reinforcing fiber from the hose >:(.
The mill was stored at my house that winter and I had left my tool box under the hydraulic box. That gave the rat a nice platform to hop up into the hole that the second pump would sit over, if I had a second pump.
Bruce    LT40HDG28 bandsaw with two 6' extensions, ED22 twin blade edger.
Offline petefrombearswamp
  • me & my son
« Reply #23 on: January 10, 2012, 06:26:28 pm »
The only hose I have had fail is on my 2008 WM lt40shdd51 where it rubbed on a fitting.
WM replaced it but lost a little time which is not important to a retired slow sawyer.
My wood splitter which I built in 1979 with NAPA built hoses is still intact.
LT40SHDD51
Kubota 900 RTV
241 acres of woodland
wife who understands my quirks
Offline Paper Maker
  • Paper Maker
« Reply #24 on: January 10, 2012, 06:32:36 pm »
i wish i had a picture of my woodsplitter hoses... most folks wont help me split wood. they get one look at the rusted what used to be hoses on there and back way up.... i think the outer covering of rubber came off a few years back.
    I bet your wood splitter hoses aren't as bad as mine. smiley_smug01
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #25 on: January 10, 2012, 06:49:56 pm »
The one that just failed is the one coming out of the frame to the base of the in/out clamp cylinder.  Only about 10" out of the frame it goes to a 3/8 elbow pointing directly at it.   This moves up and down a bit and turns 90 degrees with about a 5" radius into the frame.  Right there is where it failed.     WM is now selling one that is 26" longer (171") which I ordered ($45) .   They said it was changed in 2002 from a previous 145" .  Since the distance to the frame hole with the current elbow position is only about 10", it seems that one is expected to point the elbow in a different direction and use the excess line to make a better position which will bend less.  We'll see.
I also ordered the hose to the top of the same cylinder since it is scuffed at the bend and looks suspicious.  And a spare 3/8 in the longest size that my mill uses.  I already had a 1/4" spare which is what I am getting by with now (plus about 6 Napa fittings to increase it to 3/8 at the ends).     These hoses all cost about $40-45.   Not sure if I could do better elsewhere.  I will shop around now to see if I can get them cheaper so I'm ready the next time.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   W-M LT40SHDD w/42HP Kubota, Peterson WPF 10-30 with chain slabber. LogRite fetching arch, capstan PortaWinch, W-M CBN sharpener/dual setter. Rens P4000 Metal detector.
Offline Larry
« Reply #26 on: January 10, 2012, 06:59:43 pm »
A stop by the VFD netted me a 10' piece of junk fire hose.  Perfect to protect my hoses in spots subject to abrasion or to add resistance to bending.  I’ve also put them to use on the forklift.
When prices get too high somebody always steps up to the plate.  My neighbor is building an addition to his shop for the sole propose of making hoses.  He is gathering fittings from auctions and buying bulk hose.  The dies are a bit expensive so he has been shopping eBay.  I sawed out his rafters...at no charge, just in case.  And a little side note.   This guy is up in his late seventies...no time like the present to start a new business.
Larry
Nine out of ten trees recommend wood for your building project.
« Reply #27 on: January 10, 2012, 07:04:49 pm »
This morning before I ordered the hoses from WM I stopped in again at NAPA and asked how much for a replacement 145" 3/8 hose (JIC female fittings on each end).  I was optimistic because I thought the manager told me yesterday that it was only about $1 per foot (stupid me).  The hydraulic kid said it would be about $8 per foot  :o :o  so I passed (I don't mean I  died, I just didn't buy it-although I did really feel sick for just a bit).  He wasn't keen on splicing on a foot at the end where it was broken, because he didn't have the exact same kind of Weatherhead hose . He said $40 for the WM replacement was a bargain.
Offline Bandmill Bandit
« Reply #28 on: January 10, 2012, 07:35:53 pm »
On the reusable fittings I know that Eaton has a good line of them. They are a bit pricey but Eaton made fittings for Cat for a long time and I have used them a few times. Best to use Eaton hose with Eaton fittings if your doing new lines. Grainger distributors generally have them in stock.
Belflex is another good name.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
Offline Gary_C
  • Sunrise on the Prairie
« Reply #29 on: January 10, 2012, 08:27:37 pm »
I don't have my file here at home, but the online price is $1.41 per foot so 145" would be $17.04 plus fittings and the fittings are about $3.19 each so the total cost should be $23.42. So $40 for an OEM hose is a good price.
I know the price at O'Reillys for 1/2 inch Gates hose is around $4.00 per foot retail so a NAPA price of $8 per foot for 3/8 hose is not good.
« Reply #30 on: January 10, 2012, 08:33:27 pm »
How much does a machine cost which will put 1/4 and 3/8 JIC fittings on hydraulic hose?
« Reply #31 on: January 10, 2012, 09:12:00 pm »
Used to be around 2500 to 3000 just for the machine if you bought your supplies from the dealer. Could be double that if you got your supplies else were. Once you switch to a good quality threaded system you wont likely go back to crimped fittings.
Just checked and the prices have not changed much but how they price is different. The crimp dies are priced separate now and run 250 to 500 per set and a good crimper that will do up to 1/2 inch is about 2600 so you'd spend around 4000 for a good set with out supplies.
Offline Ron Wenrich
« Reply #32 on: January 11, 2012, 05:32:38 am »
We've always found that real cold weather will take out any hose that has a weak spot.  We had a mill that had reusable fittings, but we had to use a certain type of hose or the casing would be to thin to hold the fitting.  Don't know if that's still the case.
We have since gone to buying our own equipment to make our own hoses.  We run a lot of hydraulics with all the log loaders, lifts, firewood processor, and the mill.  We usually have hoses made in advance for those that break the most frequent.
« Reply #33 on: January 11, 2012, 06:26:55 am »
Here's a short video of pressing a fitting:
The crimper here is $2600.  http://www.discounthydraulichose.com/D165_Compact_Hose_Crimper_p/d165.htm
At $45 a hose where materials cost $20 I would break even after a hundred hoses or so.   >:( >:( >:(   Wondering if there is an inexpensive alternative for someone having just one or two types of fittings to do this with a manually operated machine.
Offline rockman
  • no band mill yet
« Reply #34 on: January 11, 2012, 07:21:28 am »
 Dennis, If you seriously are looking for hose making equipment, the stuff can be had used for pennies on the dollar. Since the economic down turn alot of repair shops, construction companies etc. have folded as you know, many of them had hose making capabilities. What you need to do is find a hydraulic hose fitting distributor for your area, Aeroquip etc. they will hook you up with a previously owned machine.
 Good Luck,
   Kevin
kioti ck-20 loader backhoe, box blade, disk, log arch
Husqvarna 455 rancher
Lincoln Ranger 10,000 welder
Offline Al_Smith
« Reply #35 on: January 11, 2012, 08:08:08 am »
Just a side note on general hydraulics .I have the Parker  Hannifin service manuals on pumps devices  etc .
It points out longgevity  issues relating to operating pressures .I think the trend these days seems to be higher pressures and smaller components .
Stuff designed for example for the automobile industry  in the 60's used massive components and high volume pumps ran at lower pressures and they would literaly go decades with low failure rates .For example they used 3000 PSI components ran on 600 PSI .
Probabley do to the trend of building machinery with an expectant service life of 10 years as oppossed to older being 30 years has caused the movement to go this way .Cost,ya know .
BTW my home made splitter uses a Parker super duty 5 inch cylinder rated at 4500 PSI which is ran at 1900 .It should out last me . ;)
Offline Tom L
« Reply #36 on: January 11, 2012, 08:40:51 am »
I got this one from MacMaster Carr back in 2002.
I have a whole drawer full of those thing that I picked up in an auction, they come in very handy. I just keep several lengths of hose around and if something breaks it is an easy fix to make them up myself.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #37 on: January 11, 2012, 06:12:07 pm »
  I bought a Dayco, now Parker, hose machine several years ago with a large assortment of fittings and hose.  I got it on E-bay and went to Southfield, Mi to get it.  Best piece of equipment I ever bought.  It's paid for itself many times over  8)  I can do hose from 1/4" to 1 1/4".  The big mark up in custom hoses comes with the assembly.  I've bought the fittings and length of hose I needed and pressed them my self and saved about half over having the shop press it.  In just the last three days I've made three 36" 1/2" hoses with #10 JIC female on both ends for the forwarder, three 1/2" hoses one 24", one 36" and one 48" with #8 JIC female fittings for the harvester/processor.  I made up two 3/4" hoses for the firewood processor a week ago.  It's pretty DanG convenient  8) 8) 8)  I can get fittings and hose from a local supplier just as cheap as I can online and keep a selection of NPT, and JIC on hand along with a variety of adapters.  If you only need a couple hoses a year owning your own hose press probably isn't worth it but if you've got machines with lots of hoses they are more than worth it  :)
Saw Anywhere!
