Get your Forestry Forum Hats while they last!
I would shop around for hoses. If you can take the time to anticipate and have some on hand it will help you to not "fall" victim to the $$$ most places that make custom hoses charge (ALOT). I usually end up at my NAPA if time is of the essence, but OUCH it usually hurts. Find out if WM is mostly "JIC" or other style. then keep them handy. "Hardlines" are REALLY costly. I hate to even thiink about replacing them. Ironwood
some hydraulic hoses can last a lifetime ,depends on weather exposure and how much fitigue (flex) they are subjected to ......i use these reuseable hose fittings just cut the hose and screw the new end on ....i have also used 2 fittings to repair a long hose in the middle ......a great time saver and a pocket full of $$$ (Image hidden from quote, click to view.)
The hoses on our 2002 WM still look good. But the mill has been under cover since new. Last Friday about 3:30, Mary went into a panic mode hollering and waving, "Shut it down!". The hose to the back support cylinder had blown a hole. Like you, I couldn’t see what had damaged it.My first instinct was to get a hold of a reusable butt splice fitting. With a reusable fitting, one can make field repairs. We called the local NAPA store and they had none. Time was running out. We called around and nobody had reusable fittings. One place suggested a large truck dealer in another town. They were already closed and wasn’t open on Saturday.So Saturday morning Mary and bit the bullet and pulled the old hose. I sent her to town to get the line butt spliced. Even thought it was a common hose size – 3/8” – they didn’t have a butt splice but could come up with a combination of couplings to put the line back together. It took us, in total until noon to get the hose out, repaired and put back in. When we pulled the hose, we attached a piece of hot fence wire and pulled it through the frame. When we reinstalled the hose, we applied dish soap for liberation. We had a couple of complications that were a result of disassembly and reassembly so we didn’t get started sawing until 1:30.I’m going to try to find a source for reusable fittings so I can make my own repairs and not have to disassemble and pull the hose. I see a number of them listed on E-bay, it’ll just be a matter of getting the right size. Buildthisfixthat,Where did you come up with the reusable fittings?(Image hidden from quote, click to view.)I got this one from MacMaster Carr back in 2002.
