Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: WM-LT40HD Wavey cuts?  (Read 1120 times)
Offline pineywoods
Re: WM-LT40HD Wavey cuts?
« Reply #20 on: January 09, 2012, 11:46:47 am »
I can usually fix blades with this problem. Usually is 1 or more teeth with way more set than the rest. Most setters won't fix an over-set tooth, just find the offending tooth, hammer it flat on a smooth surface and then reset. Sometimes finding the offending tooth isn't easy, but here's an easy way. Clamp an adjustable wrench (cresent wrench for us southerners) so it fits loosely over the blade and tip of a good tooth. Then slide the wrench along the blade. The bad tooth will not clear the wrench.
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #21 on: January 09, 2012, 12:43:41 pm »
First of all that mark on the board is from at least one probably more teeth that are bent in towards being straight up, lack of set. If it was a groove it would be that they are bend out, too much set.
As mentioned probably from hitting something like a rock in the bark or metal in the log/board. If the hump is only on one side of the board then it is only on one side of the blade.
If you're sharpening and setting yourself you'll find it when you re-sharpen your band.
If you're sending it out to WM Resharp then turn the blade inside out so that they'll know there is something up with that blade. And they'll look closely at it and maybe able to save it.
If it's bad they'll junk it and you can have them replace it for you.
Inspecting your lumber you should be able to see where it started and maybe find the rock on the edge of the board. Or the nail in the board.
If it's a nail in the board you'd better pull it out or someone who buys your lumber will not be happy if they hit it with their planer.
Good luck with your problem.
Jim Rogers
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #22 on: January 09, 2012, 01:26:43 pm »
I always hang a tag on my blades going to WM Reharp when something has happened to them.  I will describe what happened or what they are doing.  I like to help the helper.   :)
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline John Bartley
  • Location: 13 Critchley Avenue, PO Box 36, Monteith Ont, P0K1P0
« Reply #23 on: January 09, 2012, 05:06:37 pm »
Those boards that come out with "ziggers" across them go on the free pile when I'm sawing.
"Ziggers" I take it are the lines across the boards as shown in the OP's photos's? If so, I wouldn't discount them at all. As long as they're straight, they should be well within spec's for surface finishing. This is "rough" cutting we're doing, and those boards ought to surface finish just fine! The marks show, but they're not usually too deep.
cheers
John
Offline MotorSeven
« Reply #24 on: January 09, 2012, 07:20:39 pm »
"Those boards that come out with "ziggers" across them go on the free pile when I'm sawing."
Your way missing out...those should be in a special covered pile marked "Premium Antiqued Sawmill Scroll" boards....$4 a bf. ;D
WoodMizer LT15 27' bed
Online WDH
  • April 1998 - August 2008
« Reply #25 on: January 09, 2012, 11:07:18 pm »
Some people really like the look of the sawmarks of an out-of-set tooth on bandsawn lumber.  I have had people ask for it  :D.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline bandmiller2
« Reply #26 on: January 10, 2012, 06:52:07 am »
When I see that pattern I seek out the offending tooth/teeth and use a small "crescent wrench" to bend it back.I take a small piece of sticken and run it along a stopped band agenst the teeth, if you got the feel you'll know when you hit a high tooth. Usally the high teeth are from hitting something and the band should be resharpened. Frank C.
Offline paul case
« Reply #27 on: January 10, 2012, 08:57:21 am »
I guess if the bent tooth was making marks on the cant you could let the blade down just against the cant and turn the blade by hand to find the offender!
PC
EZ Boardwalk and WM 94 LT40 hd
pc
Offline Magicman
« Reply #28 on: January 10, 2012, 01:48:16 pm »
Paul, on my sawmill, the blade brake is applied when the clutch is disengaged.  It would really take two people to manually turn the bandwheel by hand.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #29 on: January 10, 2012, 05:06:25 pm »
MM, I've just pulled the handle about half way and placed a chunk of wood between the handle and the frame, works pretty good.
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline Peter Drouin
    • Sanbornton Construction L.L.C.
« Reply #30 on: January 10, 2012, 05:18:05 pm »
I just put the clutch 1/2 way on ( with the motor off) and the blade will run free. I do that with the outo clutch when I change the blade by turning the toggle up then hit the key   for a second , I like to spin the blade a little when im tightening it :) :)
Offline petefrombearswamp
  • me & my son
« Reply #31 on: January 10, 2012, 06:35:09 pm »
Thanks Peter,
I have wondered about that and in my simple mind couldn't figure out how to do it.
Pete
LT40SHDD51
Kubota 900 RTV
241 acres of woodland
wife who understands my quirks
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #32 on: January 10, 2012, 06:38:56 pm »
Ought to be able to put a magnetic base dial indicator on the rail and turn the band backwards by hand too.  Sounds like a good way to ruin a nice one too.  :o :o
DJ Hoover, Terrific Timbers LLC,  Mystic CT   W-M LT40SHDD w/42HP Kubota, Peterson WPF 10-30 with chain slabber. LogRite fetching arch, capstan PortaWinch, W-M CBN sharpener/dual setter. Rens P4000 Metal detector.
Offline paul case
« Reply #33 on: January 10, 2012, 08:40:18 pm »
ooops! sorry about that.
The ez boardwalk mill doesn't have a band brake, but my ''new to me'' lt40 does. I just didn't think of that one. PC
pc
« Reply #34 on: January 10, 2012, 09:04:59 pm »
petefrombearsswamp make sure you let the auto start cycle all the way up then back down with the key on . then start the cat .one time I forgot to do that and the cat started full throttle  :D :D :D :D I only did that one time, I all most had a heart attack :D :D :D
Offline kderby
  • Western Juniper Sawmill
    • junipersawmill.com
« Reply #35 on: January 10, 2012, 09:27:16 pm »
You guys are the bestest.  8) 8) 8) 8)
I have learned the word "Zigger" and several alternatives for my damaged blades.
I use ReSharp and the "attach a note" idea seems reasonable.  I am so focused on production that working on a blade with a damaged tooth is just time spent not money saved.  That is the same logic I apply to ReSharp doing my sharpening.  I do not have the facility, nor do I want to spend my time becoming a blade wizard.  They do it for me.  Someday I'll step up to doing it my self.  Up to now, zigger lines meant the blade was a goner.
Are zigger, bestest and goner real words?  ??? ???  Thanks Ya'lll ;D
kderby
Offline JD350Cmark
« Reply #36 on: January 29, 2012, 11:22:23 am »
  photos of the wavey redwood.
 (Image hidden from quote, click to view.) f wavey cuts
Peder,
I have cut Redwood and have experienced this finish.  I'll agree that it's something to do with a bad blade.  Do you know what type of blades you are using?  This finish is good for deck boards if you don't mind something a bit rough and it's less slippery.
2004 Wood-Mizer LT40HDG25
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #37 on: January 29, 2012, 08:27:47 pm »
     I got a box of blades a week or so ago.  I've been through all of 'em already; lots of sand in the bark.  About half of 'em had a tooth, or two, or three way overset.  I'll have to find the problem teeth and bend them back before I set and sharpen these bands.
Saw Anywhere!
