Get your Forestry Forum Hats while they last!
No pics yet, but I'll take care of that. I'm getting set up to make a bunch of oak tongue and groove flooring. Straight line rip the rough stock on my woodmaster, then run it through a shaper.
get a straight line gang rip, the money you spend on it will pay for it self in a couple months on time and labor saved. if your making floor blanks for 3" cover floor we start with a r. sawn 1x8 ripping 2 blanks at once at feed speeds at 100 l.f. per min. i guess what i'm saying is in aliitle time you can have a lot of blanks made. the most we have ripped in one shift is 8,000 sq.ft.
For straight edging moulder blanks for a small operation, I would recommend the Woodmaster. I bought a Woodmaster 725 used locally for $1200. Cheap because it had a 7-1/2 HP 3 phase motor on it which few people can use. It can be used as a single sided planer, or with the extra stuff, a sander but so far I've only used it for straight line rip, making moulder blanks that go straight into my Logosol 360. For that it works well. I put a piece of 2x2 steel angle in front, on a 12' table, as a straight edge, notched so the feed rollers don't touch. Then I set the saw about 1/4" or so from that. Put the board against the fence and feed thru at full feed speed. With care, you get a nice straight edge for the moulder. I considered an SLR and, if your operation is big enough, its likely the way to go. But it is definitely a crap shoot which can get expensive if the machine is worn out. The woodmaster is cheap and uses off the shelf stuff mostly and is reliable. Most important for me is that it works, and can be used for other things such as sanding without buying yet another single function machine.
Fellas, First I wanna thank everyone for their diligent input into my questions. I know that I may end up offering SLR services for hire at some point. ... with that in mind it seems the Woodmaster may be a little slow for what we need. Lets say I need to run off 10-20,000 LF per month.. would the Woodmaster just take too long? Sounds like it might.
