Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Timberking / Talon Sharpener and Dual Tooth Setter  (Read 1450 times)
Offline vfauto
« on: January 03, 2012, 03:19:29 pm »
I was wondering if anyone has tryed or heard anything about these products from Timber King? They look simple and are less expensive than most.
Talon Sharpener and Talon Dual Tooth Setter
The definition of insanity is to do the same things over and over and expect a different result!
Offline Chuck White
  • Sawing Mobile since 2005
Re: Timberking / Talon Sharpener and Dual Tooth Setter
« Reply #1 on: January 03, 2012, 05:37:07 pm »
Looks like a nice setter!
Seems to work real smooth.
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline xlogger
    • Pope's Custom Sawing
« Reply #2 on: January 04, 2012, 06:10:03 am »
I've got the TK sharpener and setter but just got it and have not used it yet. I got it when I got the used mill. The guy I got it from when over it so fast, I'm glad you found the Youtube on it. I've looked for one and could not find it. I hope to try to use it later in the week and will let you know how I did. Maybe I should call TK and see if they have anymore video's on them. Ricky
Timberking 2000, Bobcat 773
Offline bandmiller2
« Reply #3 on: January 04, 2012, 07:40:28 am »
Looks to be simple and effective eqipment.Only thing it doesn't look like the sharpener is profiling the whole gullet.I don't see a cam or the wheel dressing the top of the tooth only a face grind.Would be an interesting experiment same everything except sharpener and compare band life. Frank C.
Online ladylake
« Reply #4 on: January 04, 2012, 07:23:22 pm »
 Frank, the wheel is not hitting the whole gullet but is touching the top tip of the tooth after he adjusted it a bit lower.  My grinder most often does the same on the first sharpening and if I took a bit off the bottom of the wheel it would get the whole gullet but I don't bother on the first sharpening. The 2nd sharpening will get the whole gullet.     Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline bandmiller2
« Reply #5 on: January 04, 2012, 08:27:48 pm »
Your right Steve,I just looked at it again.Not a professional grade sharpener but probibly would do fine for 90 percent of bandmillers. Frank C.
Online ladylake
« Reply #6 on: January 04, 2012, 08:55:23 pm »
 I'd not rate the quality untill I saw one in person, just cuz it's simple doesn't mean it's not built good.  Steve
Offline bandmiller2
« Reply #7 on: January 05, 2012, 08:09:20 am »
Vfauto,I looked on TK's site and didn't see the grinder just the setter,must be real new.If the price is reasonable it looks like it will do the job. Frank C.
Offline davey duck
  • 607-731-7062
« Reply #8 on: January 05, 2012, 09:23:29 am »
I looked it up it was on the next page or two and its on sale for 999.00 it looks like a nice grinder.
David G.Fleming
Offline customsawyer
  • www.thecustomsawyer.com
« Reply #9 on: January 05, 2012, 09:35:31 am »
Looks to me like it will do the job. It would take some adjusting the same as any other brand but I think it would do fine. There will be a learning curve just like any new piece of equipment.
Offline tommone
« Reply #10 on: January 05, 2012, 01:39:50 pm »
The Talon sharpener looks strong, elegant and well made even though it only grinds the tooth front. If a wider grinding wheel was used and profiled to the full tooth shape do you think it could grind gullet an' all? Or is the motor HP too weak for an operation like that. Maybe the total friction would generate too much heat causing tooth bluing and upset the metal structure.  Just pondering. Anyone know  the HP of the grinding wheel motor?
Online barbender
« Reply #11 on: January 05, 2012, 03:47:27 pm »
$999 seems like a lot for a grinder that only hits the face of the tooth, or does the price include the setter too? I got my Cook's profile grinder for $1500 on sale.
I just want to run my mill
Online ladylake
« Reply #12 on: January 05, 2012, 08:28:55 pm »
 This grinder hit the whole profile of the tooth, maybe not on the first sharpening on some blades. Cant figure out where this only hits the face thing came from.  Look closely at the vid again.  And the price is right.   Steve
Offline bandmiller2
« Reply #13 on: January 05, 2012, 09:05:01 pm »
You know where it came from Steve.I wonder if its adjustable for different pitches 3/4,7/8, and 1"? Frank C.
Online ladylake
« Reply #14 on: January 05, 2012, 09:43:15 pm »
 I'd guess a different cam would take care of different tooth spacing like most grinders.  Maybe someone from TK will set us straight.  I run a Wright sharpener sold by TK for quite a few years that has served me well, never had anything but top quality come from TK.    Steve
Offline xlogger
« Reply #15 on: January 06, 2012, 06:21:11 am »
I grinded my first blade last night on my TK (Wright) grinder. Now to see if I know what I was doing :-\. I'll try it this weekend after I dull the one I have now off. Ricky
Online ladylake
« Reply #16 on: January 06, 2012, 07:12:35 am »
 Frank. I was wondering why in some later posts the hitting the face only thing kept coming up. I too thought it was only hitting the face untill he adjusted it a bit lower and it started hitting the top tip of the tooth, I'd think on the 2nd sharpening it will get the whole gullet.   Steve
Offline tommone
« Reply #17 on: January 06, 2012, 08:53:36 am »
Looked at the Talon video again, my mistake. The grinding wheel does eventually grind into the gullet but not yet convinced it grinds the back of the tooth.
Offline TimGA
« Reply #18 on: January 06, 2012, 10:51:04 pm »
Hey guys, I have the sharpener and setter. The sharpener grinds it all face, gullet, back. Like Steve said 1st grind just face. 2nd time lower stone gets into gullet. 3rd time up the back. Like Customsawer said takes a little getting used to. You have to put a small radius on grinding wheel to match gullet profile. A rock is provided with machine to make profile. It is adjustable to do different pitches, a little tedious, I only do 7/8 ths. I start at the weld and let it go have not timed it aprox 4 to 5 min, per round. I use an engraver and # next to the weld for each sharpening works well easy to read. I would say it does a very good job, should last a long time.         The setter I am Just starting to use. I read the directions 2Xs Before starting setup. It took quite a while READ CAREFULLY the setup procedure. As I have only used this on a few blades I am still learning. It does appear that it is going to work quite well though. Very simple process once you understand the settings. Setter is built well will last a long time.  I got my sharpener free on saw deal. The setter was 850.00 at the time. TK runs specials on these items ocassionally.   Hope this helps.   Sorry to be longwinded tryed to tell it all at once.      Tim
Online ladylake
« Reply #19 on: January 07, 2012, 07:28:05 am »
 Tim   Try moving that slide on the top of the machine out some, that should give you a little less up-down movement resulting in following the profile better on the first grinding.  My Wright grinder is quite a bit different but if I shim the hieght adjustment rod in or out I can make it follow the profile of almost any blade, this changes quite a bit going from a 10* to 4* hook angle. I really don't worry about hitting the whole profile untill the 3rd sharpening.    Steve
Saw Anywhere!
