Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: 30" pine 17' long off center pyth how would you cut? pic included  (Read 1568 times)
Offline isawlogs
  • A smile is contagious ... Start an epidemic
Re: 30" pine 17' long off center pyth how would you cut? pic included
« Reply #20 on: December 21, 2011, 06:22:03 pm »
Beenthere,
 Are you saying that badly off centered southern pine will not react or twist or cup ???
I've sawn a lot of wood, and this type of off centering has never gave much usefull lumber, but then I don't know much about Southern Pine, school me.
   Marcel
Offline beenthere
  • EIEIO
« Reply #21 on: December 21, 2011, 07:03:19 pm »
I expect the southern pine with that offset pith will behave badly (warp, twist, and/or cup).
More so than a 'western' pine with similar offset.  ;)
Online WDH
  • April 1998 - August 2008
« Reply #22 on: December 21, 2011, 07:47:07 pm »
I hope that somebody needs a whack of rocking chair rockers  :D.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline bandmiller2
« Reply #23 on: December 22, 2011, 07:07:07 am »
I'am no expert but I would slab it four sides and forget about it for a few months then true it up and cut to dimentions,there will be loss whatever you do. Frank C.
Offline isawlogs
« Reply #24 on: December 22, 2011, 09:40:21 pm »
 Cut it up how ever you want , it will be a learnin' experience for you  ;) :P   Then you may do like me and saw those up to put on the ground to put logs on while they wait to be sawn.  :)
   Marcel
Offline zopi
« Reply #25 on: December 22, 2011, 11:39:44 pm »
Chainsaw carving stock....
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline Meadows Miller
  • The Walkabout Sawyer
« Reply #26 on: December 23, 2011, 04:28:39 am »
Gday
Stuff like that usually gets cut into low grade material with me but that being said I have cut logs like that at afew mills into whatever they wanted  ;) the thing that has going for it is the diameter Mate ;)
Regards Chris
Jackson Lumber Harvester RMP 50" Manual Circular Mill #132 with Jackson Lumber Harvester Portable Edger, Meadows #2 delux manual circular sawmill & Edger, 1997 International 4700 Flatbed
Offline bandmiller2
« Reply #27 on: December 23, 2011, 06:54:26 am »
Wood will be wood and will do as it pleases,we can have our thumb on the scale somewhat but if its going to twist its going to twist.Cut it, stick it, with weight on top and move on. Frank C.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #28 on: December 23, 2011, 08:05:42 am »
This is an absolutely perfect example of a situation that Dodgy Loner and I were discussing last week.  This is not an unusual example that you will find when sawing SYP.  The pith may even be offset on the other side of the log on the other end.  You can not make perfect lumber from an imperfect log, but you can not discard it either.  I have sawed many thousands of board feet of framing lumber from such logs.
We often talk about "centering the pith".  That works with good logs with almost centered piths.  It doesn't always work in the real world when sawing off center piths.
In this instance, you have to center the log, not the pith.  Take the boards off with the pith either close to the top or bottom.  NOT close to either side.  Watch for stress and rotate 180 degrees as boards are removed.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline GAmillworker
  • My son Dalton
« Reply #29 on: December 23, 2011, 09:54:19 am »
Thank you everyone for your input.  I will be cutting this material next week.  I will take some pics. Here is a pic of the whole log and the other end.
Baker BBX resaw, 8k bdft Kiln, Madison straight line saw, 6x12 6 head moulder, double end tennoner, 8x36 Buss planer, 52" wide belt sander, GMC top kick with 18' flat bed, 5k piggy back lift, 5k cat fork lift, f-350 with 12' flat bed, new band mill in the works
Saw Anywhere!
