Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: 30" pine 17' long off center pyth how would you cut? pic included  (Read 1568 times)
Offline GAmillworker
  • My son Dalton
Baker BBX resaw, 8k bdft Kiln, Madison straight line saw, 6x12 6 head moulder, double end tennoner, 8x36 Buss planer, 52" wide belt sander, GMC top kick with 18' flat bed, 5k piggy back lift, 5k cat fork lift, f-350 with 12' flat bed, new band mill in the works
Offline kelLOGg
  • Good, fast, cheap... pick any two.
Re: 30" pine 17' long off center pyth how would you cut? pic included
« Reply #1 on: December 20, 2011, 05:33:36 pm »
Can you show pics of the whole log? Are there knots? That would help in deciding.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
Offline Coon
« Reply #2 on: December 20, 2011, 05:34:49 pm »
I would load it onto the mill and start sawing it up.  ;)  :D  I guess it would probably depend on what dimensions you were going to saw it to.  Once you open up a log like that sometimes you will find all kinds of tensions and stresses in the log.  It will be interesting to hear what the pro's would do though.  ;D
Offline POSTONLT40HD
  • You saw my Ad...I saw your logs. Buy now. David
« Reply #3 on: December 20, 2011, 05:37:29 pm »
Quarter sawn Pine? Just a thought!
David
  • My son Dalton
« Reply #4 on: December 20, 2011, 05:45:27 pm »
This log is free of knots along with the next cut from the same tree that is 14' 6" long.  Yes, I was thinking quarter sawing.  didnt know what kind of tension with pyth that far off center.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #5 on: December 20, 2011, 05:58:37 pm »
http://www.forestryforum.com/board/index.php/topic,686.0.html#
check out this post by Tom.  Tension and compression wood makes for good rocking chair parts...
lots of dull bands and chains
Offline beenthere
  • EIEIO
« Reply #6 on: December 20, 2011, 06:50:24 pm »
Can see some serious compression wood in the end of that log. That has longitudinal shrinkage that will be tricky to balance in whatever you plan to saw out.
What are you planning to saw from it?
  • My son Dalton
« Reply #7 on: December 20, 2011, 06:56:15 pm »
Planning on cutting framing lumber for new home.  Some exposed beams and ceiling boards.
Offline customsawyer
  • www.thecustomsawyer.com
« Reply #8 on: December 20, 2011, 07:35:03 pm »
As you cut it the board will most likely move on you one way or the other. Keep a eye on this and relieve the stress as you go.
Offline DanG
« Reply #9 on: December 20, 2011, 07:38:30 pm »
I would load that sucker up and take it to Jake. ;D
Offline zopi
« Reply #10 on: December 20, 2011, 08:51:08 pm »
Take up boat building, unless you have some big honkin' clamps to dry that stuff in...
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Online WDH
  • April 1998 - August 2008
« Reply #11 on: December 20, 2011, 11:04:20 pm »
That is a pretty extreme example.  I bet you get some nice curved lumber.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #12 on: December 20, 2011, 11:50:58 pm »
 I can tell you righ now that you going to get much if any usefull lumber out of that log. As you saw it the boards or timbers will react, twisting curving or both. As said many rocking chair parts. Too bad it sure looks to be a good size log. :-\
   Marcel
Offline 5quarter
« Reply #13 on: December 21, 2011, 12:22:35 am »
Somewhere Tom talked in detail about how to saw that. I'll try to relay what I can remember. draw a line between the tension and compression wood on the end of the log. take lumber from one side or the other, but do not cross that line, as the resulting board will twist like a pretzel. further, try to keep the ring pattern uniform throughout each board...as it will shrink more uniformly with less chance of defect.
   I would add that if it were my log, I would not saw it for anything but siding, and I would wait until I needed it. Screwing down green 1x boards will overcome any reaction tendancies the wood would otherwise exhibit during drying. I'm guessing the tree was straight but had very heavy lean?
    I would consider using the compression wood for bunks when you are putting together your next base frame for air drying. If they are screwed down to the stretchers and the stretchers are screwed down to ties or pilings and you build a lumber stack on it right quick, They will dry true.
Offline Brucer
  • The Kootenay Sawyer
« Reply #14 on: December 21, 2011, 01:12:28 am »
If it were mine, I'd be cutting a couple of big FOHC timbers out of it. Saw them oversize, let them air dry, and resaw them straight.
Just saying ....  :)
Bruce    LT40HDG28 bandsaw with two 6' extensions, ED22 twin blade edger.
Offline lynches lumber
« Reply #15 on: December 21, 2011, 07:44:04 am »
Im gonna have to keep up with this also and do a little studying too. Drug home some hefty pines from the neighbors yesterday. One was about 30" or better and the pith probably wasnt 4 or 5" from the edge. Like 5quarter said it was good and straight but probably had a 60 degree lean to it. Didnt have no problem deciding which direction to drop it.
Offline beenthere
  • EIEIO
« Reply #16 on: December 21, 2011, 09:54:32 am »
My thought reading some reply's is some don't know southern pine, and this I believe is a southern pine.  :) :)
Offline LeeB
« Reply #17 on: December 21, 2011, 04:25:30 pm »
I have to agree that 1x sisding would be your best bet. Put the pith at the top or bottom and centered vertically. Take a couple of boards, flip 180 degrees and continue this till it's sawn. Also as mentioned try your best to keep the growth rings even. It will want to bow end to end this way, but that can be delt with if you are using it for siding.
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 1966 Chevy C60 w/ dump bed.
Offline jim king
« Reply #18 on: December 21, 2011, 04:53:50 pm »
Never having sawn a log like that it just looks like a quarter sawn dream to me.  It certainly would not be less stable than flat sawn  ???
Offline LeeB
« Reply #19 on: December 21, 2011, 05:34:41 pm »
Not good for qs. Qs tends to bow toward the pith any way and this log will have an even greater tendancy to do so.
Saw Anywhere!
