Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Skidder or Tractor  (Read 3523 times)
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
Re: Skidder or Tractor
« Reply #60 on: December 31, 2011, 08:12:12 am »
having read this posting and getting a better flavor of the discussion. couple of things come to mind..nothing will beat a purpose built piece of equipment for a job...skidders obviously are exactly that. When considering tractors...I have to say there is no replacement for displacement! A few things I have learned over the last 20 plus years relative to old farm tractors. As Mad Murdock has pointed out ...rops is something you want. Snag a log at the wrong time and you can pull a tractor over on yourself. Out here seems like every few years that happens to farmers like me using ag equipment in logging applications. Also I can tell you every hose, linkage (throttle!), wire,  light and corner of a cab will be tested by brush, limbs etc. My poor international 1066 doesn't have many lights left. I'm considering getting a tractor with no cab (Rops as a bar).
As far as those 4x4 utility tractors..very handy for smaller stuff (under 24inchs) and dry ground..I've pulled an awe full lot with my 35hp 4x4 compact (Massey 1433 built by Iseiki in Japan, typical of the type). Problem is they aren't built heavy enough for sustained logging ops..I've bent everything related to the three point on that little tractor trying to pull too much. Also when there is mud they simply don't have the ground clearance once the ruts get deep enough to get to hard pan for traction after the 10nth trip. AND last but not least they are about the most expensive option when you consider weight/power per dollar because they appeal to a larger market and bring top dollar. A larger 60-70hp "obsolete" 2wd farm tractor with double ring chains is both cheaper and way more capable than those compacts when the logs get larger, the mud gets deeper, and the hills steeper. Something like a 7000 class ford,  or like an old 3020 John Deere in that class HP. You can find suitable tractors for well under 10k...sometimes under 5k! And if you beat them..your not out much.
As far as those "bigger" 2wd farm tractors...I love my 1066! About a $10,000 tractor used and 100plus HP and 12,000lbs with 18.4x38 rear tires & double ring chains...but its really too big. Easy power and good brakes along with a very robust 3point make it very effective and I burn maybe 5 gallons a day idling out the biggest logs I have. Just I really need a bit smaller machine, a winch and more logging friendly attachments to be more productive. I'm considering retiring the 1066 back to all farm activities and finding something more suited ...a tractor in the 70 to 90hp class with no cab, at least 34in rear rubber; maybe 38's. Bet I find one for around 5k that will work just fine..
Something that still has use in the farming operations, our main deal here:
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6560831&
http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6609622&
Last but not least, for the price of a good compact you can start considering the larger true ag 4x4's in the 70plus hp range.....another story! Yet again a level above the 2wd tractors..! For the 15k class you could have a real pulling machine! Something like: http://www.tractorhouse.com/listingsdetail/detail.aspx?OHID=6647701&
Husqvarna 365/372 Blend, 365SP, 268 WJL, 266se/272 blend, 272XP, 272XP MotoM, 61/272XP WJL Blend, 351 MotoM, 455, 238 WJL, 440e, Homelite Two  S-XL 925's, XP-1020A, Jonsered 2094, Three 920's, CS-2172, 2040/Craftsman46cc Blend, 2051, 49sp, 621
Offline John Mc
« Reply #61 on: December 31, 2011, 10:31:32 am »
Weimedog makes some good points, and sums up the situation nicely.
I do my firewood harvesting with a 33 HP compact tractor (NH TC 33D). This is not really "logging": Since it's all going to be blocked to 16" lengths eventually anyway, I can cut the tree to whatever length works to minimize residual stand damage, and stays within the capability of my tractor. I'm also not skidding long distances: it's all on my own land, land I own jointly with a group, or on friend's land. I'm not making a living at this, so if conditions aren't right for my tractor, I can generally wait until they are. I can still drop trees, and in most cases can buck and split them where they fall, if I can't get the tractor close to bring them out. In fact, most of my processing is done at the closest point on the trail to where a tree dropped. The logging winch has made a huge difference in reaching trees, and in protecting my tractor from damage.
What I have works for my needs. I already had the compact tractor for other reasons anyway. I sometimes wish I'd gone the next frame size up (and to a +/- 40 HP tractor). Even then it would still be a compact, given my other uses for it. On some of the things I do with it, a larger sized tractor would be a problem.
If i were buying a tractor primarily for my own version of logging, it would be a bit bigger. If I were buying equipment that would be used only for logging, and needed to be efficient enough to make a living at it (or at least make some significant income), it would be much larger and/or probably wouldn't be a tractor at all.
Small time fire-wooder in a neighborhood cooperative.
Offline mad murdock
« Reply #62 on: December 31, 2011, 03:51:58 pm »
Great points weimdog and JohnMc. My only additional .02 worth to add is that there is a lot of used logging iron available for little $$. My skidder was $3,000 as is. It ran, but not great. I did manage to squeeze in about 15 truckloads of logs with it before I spent an additional $600 fixing the engine up. (granted, if you aren't turning wrenches yourself you would not get off that cheap).
Nonetheless for well under 10k there are many options. A guy just needs to put down on paper all the things he will use a machine for, then match up a machine to best fit those needs.  I am of the persuasion that if I look at used equipment, i would rather have 2 or 3 pieces of equipment that are more adept at 1 or 2 things, than try to use 1 for everything.  FWIW :)
'64 Garrett 15A, Granberg Alaskan III, Husky 372XP, McCulloch 10-10 auto, Poulan wild thing, Stihl 075, Mac 10-10A(RHP), Homlite 360, '71 Int'l 1110 Plus more toys
Saw Anywhere!
