Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Broken WM Blades new in box? Anyone else?  (Read 1307 times)
Offline Piston
  • ...Brick by brick my friends...brick by brick!
« on: December 16, 2011, 09:43:58 am »
I was running low on sharp blades for the LT 15 so I figured I'd buy another box and send in the old ones for sharpening, you can't have too many blades right?  ;D
I got the blades in the mail quite a while back, I'd say early summer sometime, but never opened the box as I didn't need them yet.  While recently milling my devilish white oak log into flooring, I needed a new blade and I was on my last freshy.  So I opened up the new box of 15 brand spankin new blades and low and behold, there were already a few broken ones?
Has this happened to anyone else on here?
I will call Woodmizer and based on my experience, there won't be a problem exchanging them, they've always treated me good in the past with any issues I've had.
However, are there any special instructions to the blades?  Should I take them out of the box as soon as I get them next time?   It seems like they broke right at the point where they were coiled up the tightest, as if the radius was much to little for them, and the stress of the bending snapped them.  OR, maybe it was just some bad welds?
“What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.”
Offline Chuck White
  • Sawing Mobile since 2005
Re: Broken WM Blades new in box? Anyone else?
« Reply #1 on: December 16, 2011, 01:22:03 pm »
Man, that is really wierd!
I've never heard of such a thing.
I've had blades still in the box and sealed with the strapping for over a year and when I took them out of the box they were perfect!
Definately a wierd situation!
Good Luck;  Chuck
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline Bibbyman
    • Warden Sawmill
« Reply #2 on: December 16, 2011, 02:45:01 pm »
You talking about blades in a flat pack?
I know we've had blades maybe as long as a year new in a flat pack and never experienced breakage.   We've sent them to Re-Sharp in a flat pack and got them back in a flat pack.  Still not a problem yet..
Sawing since '94
Offline POSTONLT40HD
  • You saw my Ad...I saw your logs. Buy now. David
« Reply #3 on: December 16, 2011, 02:58:11 pm »
This is a new one on me. I don't think you will have to open a box of of blades every time you get a box from Woodmizer.
I'd call them and ship them back. They'll be waiting at the door to get these blades back and inspect them.
I've got a box unopened for 2 months.
Let us know what happened to them when you find out.
How many blades were broken out of 15?
Were all the broken blades together or in different places in the bundle?
Was the break in the weld?
Good post. Can't wait to find out.
take care.
David
Offline beenthere
  • EIEIO
« Reply #4 on: December 16, 2011, 03:18:29 pm »
.................  OR, maybe it was just some bad welds?
So are you saying they were broken at the welds?
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #5 on: December 16, 2011, 03:32:19 pm »
I just opened a 'new' flat-pack box that I've had laying on the shelf for over a year and didn't have anything wrong with them.
Hidden Acres Farm
I got a shotgun, a shovel backhoe and 57 acres!
Wood-Mizer LT40HDG25
Offline Piston
« Reply #6 on: December 17, 2011, 02:45:22 am »
I believe this is the flat pack that you guys are referring to.  This is what they came in, it was a box of 15 and I believe only 2 were broken, but it's been a couple weeks now since I've been up there so I can't say for sure, I'm just going by the pics I took.
Here they are just after I opened the box....
And here is a closer shot where you can see the two breaks.  It appears they broke right at the welds.
Offline timbuck2
« Reply #7 on: December 17, 2011, 02:50:01 am »
You must have let them freeze!
Offline Piston
« Reply #8 on: December 17, 2011, 02:50:33 am »
I did use one of the blades already but there are 14 still in the box.  I will call Woodmizer and see what they say, I'm sure I won't have a problem returning them but I'm glad to see this isn't a known issue.
I cropped the pic so hopefully this will show the breaks a little better....
Offline Bibbyman
    • Warden Sawmill
« Reply #9 on: December 17, 2011, 03:47:30 am »
Is the break at the weld?
That’s the only reasonable explanation I can think of that would cause a blade to break in the box like that.
Out of thousands of WoodMizer blades we’ve used in the past 18 years,  we’ve on had one to break at the weld. And that one was probably back in about 1994 and while we had used it for some time.
I’ve have destroyed some blades and tried to break them up to put in the dumpster to find that they would still bend double and stomp flat and still not break.  (Although one that has been used until it breaks will normally snap easily.)
Sawing since '94
Offline Piston
« Reply #10 on: December 17, 2011, 04:05:41 am »
I'd like to say yes, the break was at the weld, but honestly it looks as if it were never even welded?
I know that can't be the case because it must have at least been tacked together or something in order to get it in the box like that, so something obviously let go once it was in the box.  The ends of the blades (where it is broken) is an extremely clean break, so it makes sense that it is at the weld, although I didn't see any 'remnants' of a weld.  But then again, I have never noticed the welds on the good blades either, so I'm lost.   ???
It doesn't help that I'm no where near the mill (or blades ;D) at the moment so I can't go look them over closely.
Offline dovetails
« Reply #11 on: December 17, 2011, 05:20:45 am »
looking at the close up, looks like they broke at weld, and next one is cracked also.The weld is easy to spot,just look for the shiney spot, or where the 2 teeth are a little closer together
1984 wm lt30,ford 3000 w/frt lift,several chain saws, 1953 model 30 Vermeer stump grinder,full wood working shop, log home in the woods what more ya need?
Online ladylake
« Reply #12 on: December 17, 2011, 05:35:28 am »
 Most likely a rookie welder or a welding machine malfunction, maybe forgot to temper the weld.    No big deal as it sure doesn't happen often.    Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline Riggs
  • philippians 4:13
« Reply #13 on: December 17, 2011, 05:51:43 am »
I worked for years at a bandsaw blade manufacturer, and imagine that the process is the same everywhere. Looks like there was a problem with the welder and the annealing process. I don't think there will be a problem getting replacements. We used to get them all the time.
Every man's life ends the same way. It is only the details of how he lived and how he died that distinguish one man from another.~Ernest Hemingway
Norwood ML 26
Offline Chuck White
« Reply #14 on: December 17, 2011, 04:29:08 pm »
IMHO, I don't think this would be correct.
Otherwise, when the blade is going through the sharpener, the grinder would come down in the wrong place and ruin the blade.
They would have to be all spaced the same, even the tooth on each side of the weld.
I LOVE MY SAWMILL
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #15 on: December 17, 2011, 05:37:31 pm »
Hello,
Never seen this. If you would call Indy ask for Janet or Randy. They will want to know the serial # of the blade. Etched to one side of the weld. They will take care of you and may ask you to send the blades back.
Marty
Red Green: If the women don't find you handsome, they should at least find you handy.
Offline dovetails
« Reply #16 on: December 17, 2011, 05:42:54 pm »
looking at the close up, looks like they broke at weld, and next one is cracked also.The weld is easy to spot,just look for the shiney spot, or where the 2 teeth are a little closer together[/quote]
Otherwise, when the blade is going through the sharpener, the grinder would come down in the wrong place and ruin the blade.They would have to be all spaced the same, even the tooth on each side of the weld.
[/quote]
 I know on my blades where the weld is, the 2 teeth are closer together,by about 1/8". Thats
where I start to sharpen them.When it gets around to the last tooth, I have to hold the blade back just a bit, or take off half the tooth. This is on a manual sharpener. I think if on an automatic sharpener it would just grind heavy, leaving one short tooth,but setting the spacing all the same after first grinding
I just measured one of my blades, spacing between teeth is 7/8 ", at the weld it's 11/16"
I took photos,but I'll be #$@^% if I can get them to post! Got tired of the error messages, email if you want to see them!
Offline wormy
« Reply #17 on: December 17, 2011, 09:29:43 pm »
I think I would Send the whole box of 15 back. i dont know if these are welded with a spot welder but if the tips on the welder are bad they will put out bad welds until it is checked. so there may be more in the box that will break
« Reply #18 on: December 17, 2011, 09:56:07 pm »
W O W !!!!! I know one guy I hope does not get a box of these blades.  :)
David
Offline barbender
« Reply #19 on: December 17, 2011, 10:59:38 pm »
 ;D
I just want to run my mill
Saw Anywhere!
