Get your Forestry Forum Hats while they last!
rexroth made load sensing pressure compensatered valves valmet used them. with an open center gear pump. am surprised you have power enought with only 25gpm. what psi are you at?
Quote from: snowstorm on December 20, 2011, 05:17:24 pmrexroth made load sensing pressure compensatered valves valmet used them. with an open center gear pump. am surprised you have power enought with only 25gpm. what psi are you at?Wouldn't the flow rate just affect the speed? I'd guess the torque would be more a function of pressure.
well sort of. on a cyl. the more the gpm then it should be faster. with a hydr. motor a little different. lets say you have a pulp loader with a 25gpm pump 2100psi. the main boom will lift a lot. but the bucket rotator dose not have a lot of turn power. most full size hot saws run what 70gpm??? at 4500psi???. at one time i had a morbark shear 14" rapid buncher it stood up well worked good and was happy with 25gpm. there used to be quite a few around here
all the math makwes my head hurt. i know the vp at quadco. interesting guy
Northforker: Are you located near Polebridge, MT?
Wow, you fellas get talking about moment of inertia and all, I have to tap out My wife and I went to NW Montana on our honeymoon back in '98. We stayed at a B n B in Eureka. I was amazed at all the logging and mills out there at that time.
Yes Ron, pretty close. My home is south of P'bridge and have a cabin north of there. Are you familiar with the area?Quote from: Ron Scott on December 25, 2011, 07:36:57 pmNorthforker: Are you located near Polebridge, MT?
