Get your Forestry Forum Hats while they last!
pto shaft for the winch gets its power from the pressure plate......clutch....how much free travel in the pedal??should be 2" if none it could cause it to slip. did bolth problems start at the same time?? they shouldnt be related
As far as the winch... the brake will hold anything, but when pulling the cable in if there's a pretty large load, all of a sudden you've got nothing. Then I can at least then set the brake on the winch, and drive foward dragging my load closer to where I can reel it in.
