Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: LT40HD Electrical Problem  (Read 876 times)
Online Klicker
    • www.freespiritfarm.ca
« on: December 05, 2011, 04:48:24 pm »
I have a 2006 WMLT40HD with acuset 2. I went to use it today I had to boost it. When I was done and it was getting dark at that time I noticed that the green light above the key  glowed and slowley faded out  could this be coused by a short.
Online POSTONLT40HD
  • You saw my Ad...I saw your logs. Buy now. David
Re: LT40HD Electrical Problem
« Reply #1 on: December 05, 2011, 05:04:54 pm »
Sounds like a battery problem. If your mill is a 2006 and its now 2011.....its probably time for a battery.
Also it might be your alternator. It may not be charging. Check 'em with a meter.
Good-Luck.
David
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #2 on: December 05, 2011, 05:40:01 pm »
If you are saying that you had to boost it to start, then obviously you need a new battery.
As just mentioned, a voltmeter is really not an optional item.  This shows that the alternator is producing the proper voltage.
Sometimes you need to know.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Online Klicker
« Reply #3 on: December 05, 2011, 07:40:26 pm »
I replaced the battery a little over a year ago and it had been sitting for a while. I never saw the green light stay on when the key was taken out. Rod
Offline Magicman
« Reply #4 on: December 05, 2011, 08:01:11 pm »
Key ??  I re-read your original post and anything that I might say would be a guess.   :-X
Online POSTONLT40HD
« Reply #5 on: December 05, 2011, 08:15:06 pm »
When you take the key out, you will not see the green light on because there is no power. Hope we're on the same page??
David
Offline TimGA
« Reply #6 on: December 05, 2011, 08:49:47 pm »
Klicker, How long did you run the mill after jump start? Did you have any problems with any electrical fuctions while running? Did you try to start the engine when you were finished? If you ran the mill for say at least an hour with no problems and it started back up with no jump, it would appear that alt and batt are ok. Has this just happened once or a continuing problem? If it will not start in the morning I would load test the batt after giving it a full charge. It sounds like you may have a short, with key in off position disconnect the ground cable from batt, then touch the cable to batt post watch to see if you have a small spark, you should not.                     Hope this helps.    Tim
Online Klicker
« Reply #7 on: December 06, 2011, 05:54:44 am »
Thanks I didn't think that the light should be on when the key is shut off. I will call the dealer to day.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #8 on: December 06, 2011, 07:13:29 am »
Perhaps a random fact but it might be pertinent to your situation which obviously has also to do with your battery.    The green light above the key is powered by the ACC terminal of the key switch.   The ACC term on my 2001 LT40 super front remote has three other wires attached to this terminal, one is the little red (12V) wire to the big solenoid which provides connectivity to the hydraulic strip, another is the little red wire to the accessory solenoid in the big electrical box on the head.  If one of those solenoids is bad, it can somehow be sending 12V to the ACC stud via their small red coil wire, don't ask me how, ive never been inside a solenoid.  I recently replaced the big solenoid referred to above (after 11 yrs) because it was occasionally staying stuck on and powering the ACC stud , leaving the light on when the key was off.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   W-M LT40SHDD w/42HP Kubota, Peterson WPF 10-30 with chain slabber. LogRite fetching arch, capstan PortaWinch, W-M CBN sharpener/dual setter. Rens P4000 Metal detector.
Offline sparks
  • Sponsor
  • Woodmizer Electrical Tech
« Reply #9 on: December 06, 2011, 02:16:01 pm »
You may be getting a back feed of voltage from a capacitor. As mentioned, the ACC terminal power the light and other components. You could remove the wires one by one and cycle the key to see which wire is causing it.
You never want to jump the sawmill. Remove the cable ends and charge the battery. Jumping the mill can cause a voltage surge and circuit boards do not like that.
If you think you have a drain on the battery do the test I attached.
Remember we are here at 1-800-525-8100 to hel[p if you need it.    Thanks
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Online Klicker
« Reply #10 on: December 06, 2011, 03:26:40 pm »
Thanks Terrifictimbersllc and Sparky. I will try the test tonight if the rain holds off and post the results.
Sparky I have had poor help from other 1800# that I try to avoid them we have a good dealer here in Nova Scotia  but not for much longer as he is retiriing at the end of the year. That I just call him but it was after 5pm so I posted here.I have meet the new dealer and his wife he  should do well.
Online Klicker
« Reply #11 on: December 06, 2011, 04:25:46 pm »
There is a short in it somewhere as the test light lights up when you do the test or touch the NEG and the frame of the mill. So I left the neg unhooked.
Online POSTONLT40HD
« Reply #12 on: December 06, 2011, 04:35:18 pm »
KLICKER.....KLICKER.....OH KLICKER. Please call 1-800-525-8100 and ask for Michael Ecenberger. I have spelled his last name wrong, I know, but ask for Michael in electrical. This guy, in my opinion is WOODMIZER'S top electrical man,
He can walk you through anything that has to do with an electrical problem on your LT 40.
Like NIKE says "JUST DO IT!" He can help. I promise.
David
Offline pnyberg
    • CT Logs to Lumber, LLC
« Reply #13 on: December 06, 2011, 05:50:59 pm »
Oops.
--Peter
2009 WM LT40G28-RA sawmill - accuset 2, debarker, lubemizer, board-return, 4 FA outriggers
LogRite Fetching Arch, 72" MegaHook, 48" cant hook, 48" peavey, 36" Hookaroon, 30" Mill Special
Stihl MS270C & MS170 chainsaws
Kubota B2630 with FEL & BH
www.ctlogs2lumber.com
Online Klicker
« Reply #14 on: December 06, 2011, 06:54:54 pm »
If I can't figure it out I will call.There aren't that many wires on a mill it shouldn't be to hard to figure out. I probable will not get back to it till next Monday.
Offline jackpine
« Reply #15 on: December 06, 2011, 09:01:16 pm »
I am late getting to this thread but I thought that was normal ;D My lt-40 has been doing that for as long as I can remember and so far no other electrical issue.
Bill
Offline sparks
  • Sponsor
« Reply #16 on: December 07, 2011, 09:08:43 am »
The only things that are powered when the key is off it the starter and the alternator. Disconnect the hot wire from the alternator and see if the test light goes off.
Offline Magicman
« Reply #17 on: December 07, 2011, 09:27:09 am »
Yup, a faulty diode in the alternator would explain the light and the reason that the battery drained and had to be "jumped".
Offline Slingshot
« Reply #18 on: December 07, 2011, 10:19:55 am »
    Magicman,
                   Reading this reminded me of a problem my son-in-law has with a Ford
            pick-up truck, early 90's. The battery drains when the engine isn't runing and
            no one has been able to determine why. He has to remove a battery cable
            after using it and it shows no spark when reconnecting. Could the alternator
            be the problem even though it still charges the battery?
_________________________
charles   sling_shot
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #19 on: December 07, 2011, 10:28:52 am »
Oops.
--Peter
X2 Peter.
Done it several times over the years.  Guess I was lucky!
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Saw Anywhere!
