Get your Forestry Forum Hats while they last!
One way to deal with those big logs is make a ground (or bolt on) track for your mill head to ride on.
If you are a newbie to timberframing, and really need to build over the winter and spring, you need to get up to speed quick. In that case I'd recommend that you partner with a timberframer to help you design, cut your project, while teaching you at the same time. Another option would be to hold a workshop at your place with a good framer who has held workshops before. You will learn in the workshop, while working on your project, and having other students there to offset the cost of the event.
Jimdad, I am assuming here when you say "poplar" you are refering to "Tulip Poplar" or "Yellow Poplar" and not "Popple" which is a regional term for Aspen. Aspen should not be used for framing. Yellow Poplar is a strong and light wood and frames well if you can get it to dry correctly and stay straight. That said it is very prone to wide, deep checks. If you are doing boxed heart framing this is not that much of a concern as the check never passes through the heart but with the way you are sawing, the check could split the timber clean in half. Twisting is also an issue. Try to verify that there is no spiral in the bark of the trees you select. I once cut some braces out of poplar that were not boxed heat and after they dried, you could split them in half by hand. Just a few wood fibers were holding them together. Poplar is noted for making good siding. With logs that size you might want to cut the outside off for siding until you reach the size timber you desire wich would be boxed heart center and good for timber framing.
