Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Hack and Squirt Newbie to the forum  (Read 1203 times)
Offline westkane
  • Member*
« on: November 19, 2011, 06:32:16 pm »
I am working with a forester who gave me some Roundup for doing some Hack and Squirt.  Unfortunately he does not know what type of Roundup it was or where to get more (his boss bought it, but is not available to answer).  I need to buy some more stuff to do a bunch more land, much of it is Beech.  Can anyone point me in some directions?  I see Forestry Supplier has some pricey stuff, looking for something a bit cheaper and locally available, timber market sucks so we are having to watch cash flow, but still want to take care of our properties.  Thanks
Offline Shotgun
  • Retired...What's not to like?
Re: Hack and Squirt Newbie to the forum
« Reply #1 on: November 19, 2011, 06:35:51 pm »
And I'll bet the "Roundup" your forester gave you was re-packaged in a milk jug, or some other unmarked container.  That's why we have so many laws that many complain about. We do it to ourselves.
Norm
Joined The Forestry Forum 5 days before 9/11.
Don't worry about old age; it doesn't last.
Offline beenthere
  • EIEIO
« Reply #2 on: November 19, 2011, 06:42:29 pm »
Welcome
Go to a local ag store for some generic glyphosate.
Offline John Mc
« Reply #3 on: November 19, 2011, 08:08:09 pm »
Ag stores, Home depot, etc. carry RoundUp (generic name glyphosate). They've usually got it in higher concentrations than the local hardware store.
Having never done hack and squirt, I can't tell you what concentration you'll need in order to be effective.
Small time fire-wooder in a neighborhood cooperative.
Offline WildDog
« Reply #4 on: November 20, 2011, 05:18:59 am »
For our eucalypts I use straight round up @ 2ml per cut. In dry times and light country these can take a bit of killing, cuts close to the ground etc, a couple of years back I bought cheap glyphosate 360 as a generic roudup, great for spraying and got a quick kill straight up with hack and squirt but it was thinner and some trees trees started to sucker the next year. Just my observation but I am back to the original "roundup". If you get Tordon over there you will find it delivers the results.
I'm not below you, I'm not above you, I'm right here beside you.    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
Offline thecfarm
« Reply #5 on: November 20, 2011, 05:23:49 am »
westkane,welcome to the forum. Properties? I take it you are talking some alot of acres?
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline WDH
  • April 1998 - August 2008
« Reply #6 on: November 20, 2011, 07:54:29 am »
I do not prefer roundup for hack-n-squirt.  It does not seem to be as effective on our species as tordon or garlon.  The problem is you cannot buy these without an applicator's license, I don't think.  If you use roundup, use it full strength and do not dilute it.
If you get tordon, remember that it is soil active, so keep it in the hacks and do not slop it all over the place.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #7 on: November 20, 2011, 08:09:51 am »
Welcome westkane.  I am using 8 oz. of Arsenal mixed with 1 gallon of water with good results.  Arsenal is not a "restricted use" chemical.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline WDH
« Reply #8 on: November 20, 2011, 08:17:43 am »
Given the work required and the relative low cost of the chemical, you might want to apply it full strength.  The label calls for 1 mL in each hack with hacks placed no more than 3" apart.  You only have to cut through the bark and into the cambium as the cambium is the only area that the chemical affects.  Otherwise, you are just wasting the chemical.  Here is a link to the label.  Read it for instructions on how to use arsenal for hack-n-squirt.
http://www.cdms.net/LDat/ld542012.pdf
Offline John Mc
« Reply #9 on: November 20, 2011, 11:56:16 am »
A couple of you have referred to using "straight RoundUp". I'm nort sure what that means, since RoundUp is sold in varying concentrations. It's usually a blend of glyphosate and a surfactant, with some other inert ingredients.  I've never seen it in greater than 50% glyphosate concentration. I also commonly see 41% concentrations. (Both of these I only find at the Ag stores, or sometimes at Home Depot). In the hardware store, the "concentrate" I see is only 18%, and most of the "ready to use" Roundup is sold in much lower concentrations (1% to around 4 or 6%). All of these are sold as "RoundUp"
So what exactly are you referring to when you say "straight RoundUp"?
As mentioned, I've not done much hack and squirt. I have done a good bit of cut stump treatment on buckthorn, and have experimented with concentrations. The 18% hardware store concentration gives spotty results. 25% seems fairly effective, but I mostly try to stay above 30% for best results (I often just use the 40% glyphosate right out of the jug.)  I've also found the generic brands to be just as effective as RoundUp brand -- as long as the concentration of glyphosate is the same.
In Vermont, RoundUp (Glyphosate) is about the only herbicide a landowner can buy without a license (other than some of the low concentration hardware store weedkillers).
John Mc
Offline Bandmill Bandit
« Reply #10 on: November 20, 2011, 12:15:32 pm »
If you have a farmer friend he will be able to get regular "tankmix ready" Roundup or one of the other copy cat brands. Monsanto's patent protection expired about 8 or 10 years ago and the price ranges any where from 6 to 12 bucks a litre/usquart. (last I paid was $7.50 about 8 months ago for a generic)
Roundup Weather MAX
Roundup Transorb HC
Roundup Ultra2
Above are the 3 formulations available right now and ultra 2 is the slightly improved version of the old standby original Round up.
Up here in Canada you need to have your legal land location to buy any of the Ag versions of the product from and Ag Chemical dealer and be sure you follow label instructions.
Just discovered that Monsanto has a Roundup Pro Concentrate that they recommend for Roadside and Utility Management. Expect this would be the product you would want to use.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #11 on: November 20, 2011, 12:44:17 pm »
We buy Pronto from Tractor Supply. Their version of roundup. We use a quart per 12 gallons of water in the big tank or 6 ounces in the 2 gallon sprayer.  That mix will kill alder if you spray it when freshly cut.
Offline John Mc
« Reply #12 on: November 20, 2011, 01:30:12 pm »
If any of you get the chance, can you let us know what the label says for concentration of glyphosate on these? Also, does it have other active ingredients (Triclopyr or ??)
John Mc
Offline Jeff
« Reply #13 on: November 20, 2011, 01:38:04 pm »
Pronto is 41% glyphosate
Offline Dale Hatfield
  • A plan is a start to a great ending
« Reply #14 on: November 20, 2011, 07:11:09 pm »
John
you can do a label search. for any chemical that can be bought in any % that its made.
Most local ag or Farm related stores dont have mixture for Forestry use. Your % ? for Triclopyr is a tank mixture that is used for diff applications.
 Your local Soil water office, USDA will have bulletins online or in office.
If your doing this on company or for comapny owned lands, you very well need a license .  Get the books study and take the test. It will answer alot of questions you dont know about and teach you about other options .  The more you learn the better results you will have.
Chainsaw Carver
Offline WDH
« Reply #15 on: November 20, 2011, 07:40:29 pm »
I have only used the full strength roundup, 41% glysophate.  That is what you need to use for hack-n-squirt, but again, I believe there are better options.  If you want to kill grass, roundup is wonderful, but arsenal, garlon, and tordon are better on woody plants for stump treatment or hack-n-squirt in my experience.
Offline thecfarm
« Reply #16 on: November 20, 2011, 09:32:49 pm »
Jeff,I started to use that pronto stuff this year. Just could not afford the round up for just about $25-28 a quart. I bought a 2½ gallon of pronto at Tractor supply on sale for $40. Much better,works about the same from what I can tell.
Offline Jeff
« Reply #17 on: November 20, 2011, 09:35:10 pm »
It's all we use. I think its the generic identical to roundup
Online Norm
  • What's for supper!
« Reply #18 on: November 21, 2011, 06:41:53 am »
I use Tordon RTU but am not sure if you need an applicators license as I already have one. I'll stop into our ag chem supplier today and ask.
WM LT30HDD-E25
Offline chain
« Reply #19 on: November 21, 2011, 08:38:24 am »
Just bought a quart of 'Round-up'-concentrate plus poison ivy mix....18% R-up +2% Triclopyr at rate of 6fl oz. per gallon water. Very long list of trees and vines, shrubs, listed for control. We aim to use it on invasive honeysuckle this winter.
But some advice on hard-to-kill species, over 6" d.b.h... might as well double-ring with chain-saw and squirt lower ring with Tordon or Arsenal, kill 'em good and dead.
Saw Anywhere!
