Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Want to build a log arch  (Read 2119 times)
Offline Taylortractornut
Re: Want to build a log arch
« Reply #20 on: November 07, 2011, 12:34:30 am »
I helped build one a few  years ago that  was a heel type as the man I was helping called it.     It was a bit longer than a regular arch.       We made a heel like a knuckleboom has on the stick.   THis ewn near the  front of the  tongue.
You backed over the log and     got the  heel over top of the  butt of the log and     hooked the choker off center of the log.   When the winch lifted it up  the front came off the ground first and  then heeled up and  then the end would raise.  This was a big arch made with the spindles and tires off a 2 ton truck.
My overload permit starts after sunset
Offline kelLOGg
  • Good, fast, cheap... pick any two.
« Reply #21 on: November 07, 2011, 04:59:46 am »
I used mobile home axles, too. A chain hoist lifts the bulk of the log and a come-long lifts the remainder so I can get a 16 foot log completely off the ground to avoid dirt in the bark. Has a 40" throat.
Here's a pine going to the mill.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
Offline Piston
  • ...Brick by brick my friends...brick by brick!
« Reply #22 on: November 07, 2011, 06:34:56 am »
KelLOG,
That thing is a monster!  :o
“What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.”
Offline wvwoodchuck
« Reply #23 on: November 07, 2011, 09:09:01 pm »
I didn't expect all the replies.  This is great and a lot of great suggestions and tips.  Thank you all very much.
KelLOGg...that thing is a beast!!
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #24 on: November 07, 2011, 09:15:38 pm »
I am glad I didn't put a pic. of my whimpy looking thing on this thread...KelLOGg I think maybe that is the strongest looking arch I have seen.... :)  I like it....Tim
Cooks AC 36--Prentice 210C--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline kelLOGg
« Reply #25 on: November 07, 2011, 09:48:56 pm »
I did build it big - it weighs 500 lbs - at the time I thought arches should be huge. Even though I can saw a max dia of only 32" I made the throat larger so I could carry several logs at once. I even put tail lights on it because I planned to take it to a farm we own an hour away but I have never done it. I took it on the road once for a short test drive and at 45 mph it bounced like a ping pong ball because it has ~100 psi in the tires; I watched the following traffic back up to a safer distance :o  Never took it on the road again. I'll transport it on a trailer.
It would be nice to make a smaller one, too - one that can be pushed by hand over a log, pivot up and lift one end and winch it out. that project is a long way off - if ever.  Thanks for the amazement, I think. ;D
Bob
Offline thecfarm
« Reply #26 on: November 08, 2011, 05:50:09 am »
I like the tractor. Looks like an old Ford.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline kelLOGg
« Reply #27 on: November 08, 2011, 07:45:40 am »
It's a 641 year 1958. 6volt is the only thing I don't like about it but haven't taked time to convert it.
Bob
Offline Ron Scott
    • Ron Scotts Web
« Reply #28 on: November 09, 2011, 06:01:32 pm »
A good selection of arches.
~Ron
Offline caveman
« Reply #29 on: November 09, 2011, 09:12:06 pm »
Kellogg, nice arch and high voltage pine.  Caveman
Caveman
Offline kelLOGg
« Reply #30 on: November 10, 2011, 04:41:22 am »
Kellogg, ... high voltage pine.  Caveman
 :D  Yeah, it was my neighbor's tree. They wanted to wait and see if it survived the strike even though all the needles were brown in the spring ::). The tree went through the summer and fall picking up larvae and when I milled it, it was soft on the outside and solid on the inside. I cut them some fence rails for fence repair.
Bob
Offline Furu
« Reply #31 on: February 09, 2012, 08:13:00 pm »
kelLOGg
You said you used mobile home axles.  How exactly did you do it?  I assume you cut the axle leaving a short stub of axle and then connected that to the square tubing.  I am not seeing how that works without undue torque on the short axles that would break them or the connection.  Do you have any close up photos of the joint of axle to upright?  I am planning on doing something very similar only with 3" pipe that I have laying around.
Offline Spalted Dog
  • Doing the best I can with what I have
« Reply #32 on: February 10, 2012, 10:17:17 am »
I used standard trailer spindle, and hub and dot tires.  Local farm store.  No chasing parts in a yard.  $200 max w all new.  If I had more time I probably would have scrounged parts.  It has paid for itself many times.  I set it up somewhat like a decked out slighty oversized Logrite Fetching arch.  Its not as pretty though.  I can move logs around yards by hand, tractor, or atv.  I can pick a 30" log.  I have also used it at the small end of tree length trees with th tractor and winch.  I would use caution hauling at road speed, if the log isnt rock solid, bad things can will happen (i got lucky)
The older I get the less I used to know.
Offline rogdan
« Reply #33 on: February 10, 2012, 04:31:54 pm »
 A couple of other designs:
 By a fellow Mountaineer using an engine hoist http://myfrenchforest.blogspot.com/2010/10/log-arch.html:
 winchless
Out of the box  http://www.bercomac.com/accessories-30-skidder.php
Another forum member http://www.forestryforum.com/gallery/thumbnails.php?album=2254
Offline Lud
  • Impetuous.... Homeric....
« Reply #34 on: February 11, 2012, 06:38:57 am »
I built my arch out of an old transport disc.  The split axle  lets me straddle the log, lift with my tractor mounted winch and back over the manual mill as well.
I've hauled good size sticks on the country roads in 4th gear high range up to 6 miles.  Just showing that a bigger arch can have it's uses. 8)
Saw Anywhere!
