Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: need help keeping my pine from stain an mold...  (Read 1612 times)
Offline pitsaw
« on: November 03, 2011, 01:54:46 pm »
I've never had much luck airdrying yellow pine without stain or mold an need help.Uselly I don't mind cause most goes for barn siding or fence but I just sawed 1000 bdft to panel the inside of woodshop an want to keep this stuff looking nice. I uselly sticker with 1" stickers ever 18" an in a open sided barn and a big drum fan with no luck. I thought maybe I would have better luck sence its cooling down here in florida but the stuff I cut last week is moldy as heck. Is it just me ?  Thanks in advance Jason
Offline Den Socling
  • Board Moderator
  • just wondering
    • PC Specialties
Re: need help keeping my pine from stain an mold...
« Reply #1 on: November 03, 2011, 03:53:28 pm »
It sounds like you are doing everything right. My guess is that your mill is polluted with mold spores. Nothing unusual about that and not a lot you can do. I would suggest that you buy a box of Borax and mix a solution of one cup Borax to one gallon of water. Spray it on your wood while stacking.
Offline T Welsh
  • Woodmizer LT-40-HD and a whole lot of toys!
    • Welsh Tree Service
« Reply #2 on: November 03, 2011, 05:37:13 pm »
Like Den, sounds like your doing everything right. where are you stacking and drying. in a damp location? if so,you need to get it some where that is good and dry right away and keep it that way with plenty of dry air circulating through it. Tim
Offline red oaks lumber
« Reply #3 on: November 03, 2011, 07:11:02 pm »
how fresh are your logs? if they been cut for awhile, once you cut them into lumber all the added oxyegen will really speed up mold or bluestaining.
i know nothing related to wood
Offline pitsaw
« Reply #4 on: November 03, 2011, 07:43:19 pm »
most of my logs only sit in the yard a few days  from the time they are cut.I saw them an sticker'em never deadstack.I'll the try the borax trick an see what happens. would 20 mule team borax be alright?
Offline Den Socling
  • Board Moderator
  • just wondering
    • PC Specialties
« Reply #5 on: November 03, 2011, 09:46:35 pm »
That's the stuff.
Offline WDH
  • April 1998 - August 2008
« Reply #6 on: November 03, 2011, 10:28:32 pm »
Stain is caused by a fungus.  In the South, after a pine is felled, you can have as little as one week before the blue stain sets in when it is hot and humid.  The only cure for this is to saw the lumber as close to tree felling as possible.  As for the the mold and mildew, that sounds like too much humidity and too little air flow.  That is a problem in Florida  :).
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline cypresskayaksllc
    • Cypress Kayaks LLC
« Reply #7 on: November 03, 2011, 10:55:22 pm »
Im in N FLA.  Some of my logs develop mold and some dont.  I use pine for utility purposes.  I let my cherry and sycamore be seen and I dont have a mold problem with those. An open field on the top of a hill is the best place to stack wood. High and dry.
LT40HDDR, JD950FEL, Weimaraner
Offline pitsaw
« Reply #8 on: November 04, 2011, 09:37:27 am »
The stuff I cut the other day didn't have any stain in it yet so If ican keep it from molding I should be good.Thanks you guys I'll try the borax. as far as hill's I'd have to make my own cause its dead flat round here...
Offline logboy
« Reply #9 on: November 04, 2011, 11:32:36 pm »
I'm not sure if it applies to your type of pine, but i usually only get mold where I've left the bark on a board. It affects all the neighboring boards as well, like a bad apple in the bushel. Otherwise I usually get no mold. I verified this yet again tonight as i pulled apart a stack of red pine 2 x 6 I stacked 3 years ago in the barn.  From now on I'll either saw all the boards clean with no wane or stack the bark boards separately.
Lucas Sawmill Model 827
Lucas Dedicated Slabber
Lucas Planer Attachment
Hud-Son Badger
Ebac 3000 Kiln... minus the chamber (its on my to-do list)
Online Planman1954
« Reply #10 on: November 06, 2011, 09:57:49 pm »
Seems I read a post once about your problem, and the fellow said that the trick is to clean the sawdust off the wood before stacking. May be wrong here, but I think I remember reading that.
Norwood Lumbermate 2000 / Solar Dry Kiln
Offline SwampDonkey
  • Large Tooth
« Reply #11 on: November 07, 2011, 05:01:33 am »
Would winter logging and sawing in the south help reduce the stain if it (resulting lumber) dried in the winter air?
Up here white pine is best cut in October and in the winter months if the logs are going to sit for awhile. And have then sawed before it warms in the spring because the sawyers and ambrosia will get to them right quick in the warmth of late spring.
Dirty Harry
Offline SwampDonkey
  • Large Tooth
« Reply #12 on: November 07, 2011, 05:08:21 am »
Logboy, check those live bark edged pine for pin hoes from ambrosia (or trails from engravers), they farm the fungus in their holes.
Ambrosia in the sapwood.
Borax will keep bugs off, but if the logs have been invaded by ambrosia the stain starts inside the holes and feeds on the sugars as it grows in the sapwood. Borax will only deter surface stain.
Dirty Harry
Offline logboy
« Reply #13 on: November 08, 2011, 10:06:28 pm »
This summer I cut a trailer load of pine up north then drove it down to my place 100 miles south. It took me three days time before I could get it off and stickered. Blue mold had already started wherever a board had bark in the stack. Swamp Donkey, are you saying the blue stain was there to begin with before I cut? Or the insects were already there? Maybe I'm wrong, but it seemed to be a microbial issue to me where the fungus was already in the bark and did not grow until the proper condition for growth presented itself. When I have no bark (sapwood or not) it rarely seems to be an issue.
Hud-Son Badger
Offline SwampDonkey
  • Large Tooth
« Reply #14 on: November 09, 2011, 09:29:55 am »
With the ambrosia, it got inoculated when the tree was down and the bugs crawled/chewed in. If it's just surface stain, then that came just after you sawed lumber, on the air, with sawdust being on the boards and not good air flow.
White pine can be a pain in the seat. We had some nice pine go to crap that was to be used for cupboards. Grandpa had to cut and skid on ice by horse and it laid on the ground in the warm season afterward and got ruined. ::)
Dirty Harry
Offline DIPMAN
« Reply #15 on: November 30, 2011, 03:33:09 pm »
I am very new to this forum but let me add my two cents to this discussion.  To prevent blue stain in GSYP during the hot/warm months of the year you need to cut the logs as fresh as possible and spray or dip the lumber with either a strong borax solution (provides short term protection) or an EPA registered anti-sapstain formulation.  SYP is far more susceptible to sap staining fungi and molds than the northern species.  Most commercially available treatments are efficacious against a broad spectrum of fungi.
Offline Den Socling
  • Board Moderator
  • just wondering
    • PC Specialties
« Reply #16 on: November 30, 2011, 03:57:46 pm »
hmm.....Welcome. You sound like a dip man. Do you sell dip tanks and such?
Offline SwampDonkey
  • Large Tooth
« Reply #17 on: November 30, 2011, 05:08:12 pm »
White pine is equally susceptible if not worst to stain. It can't lay around long at all in the warm season. I see a bunch that has been sitting at a portable mill for months and someone is soon going to learn a little more about white pine. ;D
Dirty Harry
Offline WDH
« Reply #18 on: November 30, 2011, 08:28:44 pm »
At 100 degrees and high humidity, anything, wood or man, goes bad quick :).
Offline DIPMAN
« Reply #19 on: December 01, 2011, 10:38:08 am »
I'm a development chemist and I have been formulating and testing anti-sapstain products for most of my 13 yr career.  I guess when I say SYP is more susceptible I am comparing the sapwood/heartwood ratios and longer mold/stain seasons.  Attaching a picture of Neurospora growing on a SYP peeler core (36 hrs old) that should make your skin crawl and a photo of a typical 14 day blue stain test on GSYP (note the line between dipped and not dipped).  Borax alone will not yield these results.   BTW, my wife does think I am a dip, man.
Saw Anywhere!
