Get your Forestry Forum Hats while they last!
When you say "sips" that means osb foam osb, you may only need foam then osb on top. These cost less and do about the same thing.You could try asking for these.Some companies call them curtain walls for side walls, and nail base for roofs.Good luck with your research.Jim Rogers
May I ask what kind of foam you were quoted at $1.50?? Was that per inch or for 2 inches. Just curious since I spray foam myself and that seems cheap. In my opinion you would want a closed cell foam. Fantastic looking home.
Have you got decent ceiling fans up there?Are they spinning in the right direction?
Urethane also adds structural strength that open cells and fiberglass do not and it forms its own vapor barrier.
Quote from: Thehardway on October 31, 2011, 10:53:44 amUrethane also adds structural strength that open cells and fiberglass do not and it forms its own vapor barrier.Is there VB under the R19insulation? Be careful not to create a double VB sandwich where the r19 insulation has no chance of drying out
Well here's my 2 cents worth. I built a rustic home in 1980 and used jumbo cedar shakes for shingles. I floored my attic and of course filled it with junk. To make the long story short I had to go into the attic numerous times to put stuff or get stuff. During the summer the attic was warm but never unbearably hot. Finally after 20 years the shingles were ruined in a devastating hail storm and the insurance adjuster talked me into replacing them with asphalt shingles.That summer I went into the attic and it felt like the fires of Hell. I had some old computer equipment up there with rubber feet and the rubber had melted. Our utility bills skyrocketed and the A/C ran constantly just to keep up. No telling how much the shakes saved me in utility bills over the 20 year span. I am building my own home again now and I will definitely used the cedar shakes and plan to cut my own. This was one of those lessons you find out the hard way I guess.
