Get your Forestry Forum Hats while they last!
cash talks!! Tim
You can get an 020T (200T) with a rear handle...
Don't buy a top-handle saw for ground use, you will have less contol than with a rear-handle saw. .
Quote from: SawTroll on October 17, 2011, 08:58:23 amDon't buy a top-handle saw for ground use, you will have less contol than with a rear-handle saw. . I've heard that .Maybe for the less experianced that's good advice .I've used a top handle myself for ground work for over 35 years and never had a problem .Actually in the early days it was all I had so there really wasn't much choice other than a bow saw .Somehow a bow saw never really suited me .
Larry -All of the above are lighter than your 357XP (which, if I recall, is actually heavier than the 12.1# listed in the specs). If you want to go lighter than your 240, you could look at the 435 (9.3#) or 440 (9.8#). Both still beat the 240 for power. I'm not very familiar with these saws, however.I don't know as much about the Stihl line.
