Get your Forestry Forum Hats while they last!
You could easily rig a bung or cap for road travel.
Quote from: MotorSeven on September 29, 2011, 07:37:24 amYou could easily rig a bung or cap for road travel. You will also need that cap for stationary use to prevent sawdust from entering.
I used a holesaw to cut the hole on the top of my waterjug then used the same holesaw to cut a plug from a piece of 2in board bolted to a larger square of plywood to cover the hole. Leave the bolt long enough on top to use as a handle.
