Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Does redoak take longer to dry than white oak?  (Read 1395 times)
Offline Charles
Re: Does redoak take longer to dry than white oak?
« Reply #20 on: September 26, 2011, 09:32:48 am »
Bob
I don't think the drying is taking to long. my thoughts would be that 700 bft of RO would take me 30-35 days to dry to 7%
The fact is your charge is 30% larger than normal and RO dosen't like to give up it's bound water very easily. When you start to dry you are removing all the free water first, that usually dosen't go to bad but getting the bound water gets tougher.So to me you have about 6-7 days left of drying and as I said earlier the last few % of MC slows done to about 1/2% per day for me anyway. You are at 10% and 1/2%  per day is another 6 days witch will be about 32 days which seems right on the money for me anyway.
You are still pulling water which is good, but I think your cooling coil temp may be reaching it's peak. At 110f with 10-11MC your RH should be around 60-65% which gives you a dew point of about 85f. or so and I think your cooling coil is probley around that. I don't know if you can check the coil temp but that would be important to me so you know where you stand as DHing goes. If your cooling coil temp is very close to the dew point as the RH drops you will see things really slow down.
If you have vented in the past and had success  I would stick with it, if you look at the pics of my kiln you can see some flaps on the ends and front of the kiln. Before I put on the A/C unit that's all I did was vent.
That's my take on this
charlie
PS are we the only ones on this post I am sure there has to be someone  out there that may have a better take on this than just me
I don't have a good enough knowledge on the science of drying just what I have experienced in doing it. Maybe somebody out there has a handle on the science end of it and can add something
Offline Charles
« Reply #21 on: September 29, 2011, 10:55:18 pm »
Bob
Any more info on how the drying is going??
Was wondering if you ever got a chance to check the cooling coil temp and compare it to the dew point of the kiln air
charlie
Offline kelLOGg
  • Good, fast, cheap... pick any two.
« Reply #22 on: September 30, 2011, 08:25:26 pm »
The MC is in the low 9s now. My timer malfunctioned so I can't rely on it, so I manually turn on the DH and fans for ~4hrs and off for ~20hrs. I'll limp this way til the load gets to ~7% and call it over and replace the timer. I still get water dripping at 105F so I'm still drying.
I have no way to measure thre coil temp.
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
Offline WDH
  • April 1998 - August 2008
« Reply #23 on: September 30, 2011, 08:36:23 pm »
I would think that the low 9's would be perfect for NC given your humidity.  I stickered some red oak behind the couch for a project on March 4th and took measurements all along.  The moisture content went from the mid 13's down to the mid to upper 9's and stayed right there until I removed the wood a few weeks ago.  That was with the air conditioner running all summer.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline kelLOGg
« Reply #24 on: October 01, 2011, 07:08:07 pm »
WDH, I think you're right but I will leave it in the kiln anyway because I'm too busy with garden, building a saw shed and sawing some WO a friend dropped off.
Bob
Saw Anywhere!
