Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Fast Forward  (Read 1814 times)
Offline Magicman
  • Knothole Sawmill, LLC
Re: Fast Forward
« Reply #20 on: August 26, 2011, 07:19:32 am »
Brucer, your concerns are why I visited with the technical support technician at WM.  He told me the proper leads to splice into (violet and red) and assured me that nothing bad would happen.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline Brucer
  • The Kootenay Sawyer
Re: Fast Forward
« Reply #21 on: August 27, 2011, 12:01:08 am »
 smiley_thumbsup
There's many ways to wire a potentiometer into a speed control circuit, which is why I mentioned it. Sounds like WM uses one of the bullet-proof methods.
Bruce    LT40HDG28 bandsaw with two 6' extensions, ED22 twin blade edger.
Offline Magicman
Re: Fast Forward
« Reply #22 on: November 09, 2011, 02:51:37 pm »
UPDATE
As Brucer pointed out there was a problem with the original wiring.  A single pole double throw (SPDT) switch was required to remove the shunt that the potentiometer was adding to the circuit.
The red center potentiometer lead was cut and connected to the common terminal on the Fast Forward switch.  The normally closed (NC) switch lead was then connected to the center potentiometer terminal.  The normally open (NO) switch lead was then bridged to the violet/purple potentiometer lead.
Now, the Fast Forward switch works perfectly.
Offline Brucer
Re: Fast Forward
« Reply #23 on: November 10, 2011, 01:51:41 am »
Yeah, that's what I was thinking you'd want :). It's pretty much bullet proof wired that way.
Offline Magicman
Re: Fast Forward
« Reply #24 on: November 11, 2011, 10:11:00 pm »
The Fast Forward worked better than I could have ever expected or imagined.
I found that it was better to stop with the forward/reverse lever because it places a shunt across the power feed motor terminals and stops you immediately.
Radio Shack has the momentary SPDT switch for less than $4.00.
Offline Bandmill Bandit
Re: Fast Forward
« Reply #25 on: November 12, 2011, 04:15:45 pm »
I used to deadhead to measure alot too, till got my GREEN line laser installed and working.
Now I walk down, measure to center of pith  on the big end com back and position head to the measurement and raise toe board under the close end (small end) till pith centers and proceed to cut. love that green laser it works pretty good even in direct sun. Will be adding a bit more powerfull laser though to make it brighter.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
Saw Anywhere!
