Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: sanding pine floors  (Read 1512 times)
Offline shinnlinger
sanding pine floors
« on: August 14, 2011, 06:40:50 pm »
Ok,
So my plan is to rent one of those new fangled floor sanders tomorrow with 4 random orbits.  A buddy of mine did  that to his pine and it turned out great.  My frame was going to be a strawbale though and the posts are 19 inches into the room with little return walls. What this means is rather than having 4 corners in a room, I have 16 and they are tight corners so I doubt the typical edger will get it done.
I have a Fein detail sander and maybe that will work, but It will be a alot of work and I have heard somewhere, probably here, that Dynabrade pneumatic sanders are just the ticket.  I have a decent sized (18cfm) compressor .
ANy words of wisdom here will be appreciated.
Dave
Shinnlinger
Woodshop teacher, chicken farmer
34 horse kubota L-2850, Turner Band Mill, '52 GMC Dumptruck,
living in self-built timberframe home
Offline shelbycharger400
  • m14/04 0
Re: sanding pine floors
« Reply #1 on: August 14, 2011, 07:03:46 pm »
they are touchy.  personally i never used a floor sander, but i used a 14 in industrial floor scrubber..   that thing tried to throw me round til i got the hang of it and im  5, 11, 250 lb!    orbital scrubbers and sanders..based upon how much  you push down or pull up,  they will walk... or RUN!
Get a dust collector ,  from what i heard floor sanders create a HUGE amount of dust.
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
    • Florida Inspection Associates
« Reply #2 on: August 15, 2011, 08:19:32 am »
Word of caution....
A friend sanded some floors. Must have hit a hail head and created a spark because over night a fire started in the dust bag burning down the house. Luckily it was a empty rental and nobody was living there.
Kubota L-4200, Chainsaw, Bush Hog, and 85 acres of trees I'm not sure what to do with but I sure do have fun!
The First 40 years of childhood is always the hardest.
Offline witterbound
« Reply #3 on: August 15, 2011, 09:07:38 am »
I got a rigid, I think, random orbital sander that was the same size as the pads that came with the floor sander.  I just used some of them on the rigid, and sanded around my posts.  Worked fine.  My floor was hickory, though.
Offline Brad_bb
    • My timberframe blog
« Reply #4 on: August 15, 2011, 09:24:56 am »
I rented a 3 pad orbital sander machine from Menards to do an Oak floor.  It worked great and was not hard to control like the older belt types.  A pine floor would be much softer so you'd have to be careful not to gouge anywhere I'd think.  It will probably sand faster than a hardwood floor.  Don't go as heavy a grit as you would a hardwood floor.
Offline LOGDOG
« Reply #5 on: August 15, 2011, 10:20:11 pm »
Shinnlinger ... What about a scraper card for those tight corners? I love those things. They get right in there and leave it glass smooth. You can remove a little at a time. Could work for you and they're cheap.
Offline shinnlinger
« Reply #6 on: August 16, 2011, 10:12:54 pm »
Where do I get a scraper card?
Ok,  I laid rough gut boards from my mill and there is some unevenness in thickness as well.  I have always heard that the drum sanders will burn a hole in your floor in a flash so that is why I went with the random orbit but let me till you, if you can build a house, you can use a drum sander.  I started with the orbiter but it really didn't do much.  I am now running 24 grit on a drum sander and it is getting the job done, but not as fast as you might think as I need to make multiple passes on some of the uneven seams.
Will post more as the project progresses...
Shinnlinger
Offline LOGDOG
« Reply #7 on: August 16, 2011, 10:49:37 pm »
Grizzly has them here: http://www.grizzly.com/products/6-pc-Scraper-Set/H5568
But most of the woodworking supply catalogs and websites have them as well. I think there are some video on YouTube of guys using scraper cards just in case you haven't seen one work. So simple but very slick.
Offline LOGDOG
« Reply #8 on: August 16, 2011, 11:07:01 pm »
Here's a short clip of a scraper card in action....
Offline shinnlinger
« Reply #9 on: August 17, 2011, 08:10:37 am »
thanks for the link, I have used those before and they are great for hardwood, not so much with knotty pine.  I have always just called them scrapers hence my confusion.
IN a pinch, you can use a piece of glass in the same manner and it works really well.
Shinnlinger
Offline LOGDOG
« Reply #10 on: August 17, 2011, 08:25:00 am »
Aren't you wanting to just clean up the corners where your edge sander or orbital aren't able to get into? Or did I misunderstand?
Offline shinnlinger
« Reply #11 on: August 21, 2011, 12:10:20 am »
OK,
Here is what I did to my rough cut pine boards from my mill.  they weren't all the same thickness so despite what 3 people told me, the big random orbit is not enough sander to make them level.  I did multiple passes with a drum sander starting at 24 grit to bring them down and even that was not enough.  I might even have run 24 grit on a buffer  if I was doing it all over again.  Once the floors were relatively level with the drum I then went to 24 grit on the random orbit and worked up from there.  Wife then put on some tung oil and I must says it looks pretty good.  Rustic, but good.  Works with the blue stain and knots and being pine, I know they will dent with time.
In the corners I used a pneumatic DA sander and the Fein detail sander and it worked out pretty well.  The random orbit machine gets pretty close though.
Shinnlinger
Offline LOGDOG
« Reply #12 on: August 21, 2011, 09:00:03 am »
Any pictures?  ???
Offline shinnlinger
« Reply #13 on: August 21, 2011, 09:32:29 am »
Shinnlinger
Offline LOGDOG
« Reply #14 on: August 21, 2011, 10:16:13 am »
Wow! That will look incredible when the finish goes down on that floor. I like the red/pink tones with the blue. Compliments the walls well. Looks like a cheerful home.
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
« Reply #15 on: August 21, 2011, 10:44:30 am »
Wow is right!  That floor is gorgeous!   8)
Save a farm today or starve tomorrow.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #16 on: August 21, 2011, 05:55:15 pm »
Is that T&G?  It looks like at least some of the flooring is surface nailed.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline shinnlinger
« Reply #17 on: August 21, 2011, 07:56:59 pm »
Shinnlinger
Offline WDH
  • April 1998 - August 2008
« Reply #18 on: August 21, 2011, 09:28:07 pm »
That floor will be a conservation piece for sure.  Unique and special.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline Magicman
« Reply #19 on: August 21, 2011, 10:08:38 pm »
Thanks for the flooring link.  You were flooring when I was foundationing.   :D :D  Maybe before the end of the year I will be flooring.
Saw Anywhere!
