Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Bar Life?  (Read 1725 times)
Offline bendjoseph
Bar Life?
« on: August 13, 2011, 03:39:43 pm »
I have a Stihl MS391 With a Rollomatic E.  What is the life of this bar?  I have 13.5 hours on it now, and I have had to file it twice.  The rails are discolored from heat.  I have a pic but could not get it in the post.
Offline beenthere
  • EIEIO
Re: Bar Life?
« Reply #1 on: August 13, 2011, 03:49:51 pm »
I'd be concerned about discoloration from heat. May be a dull chain and forcing the saw in the cut, and possible lack of bar oil. Not saying that is what happened, but comes first to mind.
The life of the bar should be years if cutting firewood at about 10 cords per year.
Any thoughts as to what may have caused the bar to overheat? And where on the bar do you see the discoloration?
Offline tyb525
  • Always learning.
Re: Bar Life?
« Reply #2 on: August 13, 2011, 04:02:56 pm »
Your chainmay be too tight, too dull, and/or might not be getting enough oil.
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline alderman
Re: Bar Life?
« Reply #3 on: August 13, 2011, 04:23:13 pm »
Clean the bar groove and make sure all the oil passages are open.  You might pull the bar off, start it up and see if the pump is working.
Offline bendjoseph
Re: Bar Life?
« Reply #4 on: August 13, 2011, 04:58:58 pm »
It has cut 7 cords, in 13 hours.  The heat is on the rails.  I am keeping the chains nice and sharp. The maple I have been cutting has been nasty.  Also about 5 of those 13 hours havebeen ripping.
Offline fuzzybear
Re: Bar Life?
« Reply #5 on: August 13, 2011, 05:12:50 pm »
  I think you found the problem. Ripping is very hard on a bar, especially if there is not enough oil. When you are ripping you need twice as much oil as bucking. Turn your oiler up as high as it goes and maybe add an extra oiler to the end of the bar. When the chain is spinning a portion of the oil gets thrown off the end of the bar, you need more oil to make it to the bottom of the bar directly under the chain doing the cutting. Not enough oil there means metal to metal and lots of heat.
  There is no such thing as too much oil.
FB
I never met a tree I didn't like!!
Offline bendjoseph
Re: Bar Life?
« Reply #6 on: August 13, 2011, 06:24:53 pm »
Ok, I did not turn up the oiler when I was ripping.  I kept the chain nice and sharp.
Offline Red 93 L1 #3383
  • Park District Mechanic
Re: Bar Life?
« Reply #7 on: August 13, 2011, 11:51:27 pm »
My oilers are always set at max, I just wish Stihl would squirt a little more oil out.
Stihl's: 2-064AV's, 020T, MS 310
'93 Ford F-150 Lightning, '94 F-150 4x4, '92 F-150 4x4 '80 F-150 EFI 7.5L, '04 Expedition (Wife's)
Offline bendjoseph
Re: Bar Life?
« Reply #8 on: August 14, 2011, 05:11:14 am »
I asked my dealer about the amount of oil I was getting.  I did not feel it was enough, they said it was fine.  I get one tank of oil to every two tanks of gas.  I am going to turn it up.
Offline Ianab
Re: Bar Life?
« Reply #9 on: August 14, 2011, 05:46:23 am »
3/4 tank of oil per tank of gas is more normal. Like the guys say, ripping produces a different sort of sawdust, and it seems to suck up the oil more than normal. It's either fine dust, or long noodles, but both act like blotting paper.
Turn up the oiler for sure, and make sure you are using a good bar oil. The main difference is the "tackifier" that makes it stick to the bar and chain.
Weekend warrior, Peterson 8" WPF with Stihl 090 powerhead, Dolmar 7900 and Stihl MS310 saws and  the usual collection of power tools :)
Offline rayrayrau
Re: Bar Life?
« Reply #10 on: August 14, 2011, 11:41:22 am »
Just a note, but all Stihl bars are dark for about 1/2 inch around the rails where they are hardened.  If you peeled the paint off a brand new never used Stihl bar it would be a darker, bluish color around the outside.
Stihl 009 020t 026 034s 046 051 075, Husqvarna 55 460 570 272 576
Offline bendjoseph
Re: Bar Life?
« Reply #11 on: August 14, 2011, 12:46:07 pm »
I have been running Stihl chain oil.
Offline clww
  • Location: Virginia Beach, VA now Williamsville, VA soon
Re: Bar Life?
« Reply #12 on: August 14, 2011, 08:14:56 pm »
I had the same problem with my stock MS290 bar. I bought a Forrester bar and no more problems. Don't know why  ?
As others wrote, sharp chain, keep the oil flow holes cleared and flip the bar over every 3rd take of gas. Another thing is on that particular saw, I could not adjust the auto oiler, which I do not like. My 1985 Stihl 028 uses much more oil than my 2 year old saw, and a lot fewer bars, too!
Stihl 08S           9500 Mile Marker Winch
Stihl 028 WB     2005 RAM 3500HD 4X4
Stihl MS290
Stihl MS361
Stihl MS460       "Ask The Chief"
Stihl 056
Stihl 084
Stihl 090
Offline HolmenTree
  • "Been there.....done that"
Re: Bar Life?
« Reply #13 on: August 14, 2011, 10:50:32 pm »
Only the 3 piece laminated Stihl bars like the "E" bendjoesph here is using are hardened discolored rails under the paint. But take the Stihl "ES" machined solid body bar with the replaceable nose does not have this.
I would suggest to bendjoesph to "noodle rip" your firewood blocks. [cutting the block through the side not down through the ends]Alot easier on the b/c and faster with those long stringy chips then making sawdust what you have been doing.
You just need a slightly longer b/c then your firewood blocks
Offline Al_Smith
Re: Bar Life?
« Reply #14 on: August 15, 2011, 05:26:25 am »
If you hold that bar at about a 45 degree angle when ripping it does better .Cross grain it just pulls sawdust and beats the dickens out of the cutting system .
You get the angle right you can rip right through the stuff and never clog the bar .
Offline HolmenTree
Re: Bar Life?
« Reply #15 on: August 15, 2011, 10:22:30 pm »
Thats right Al, but if you want the best speed pull off the sprocket cover, shim up the bar nuts with washers to keep the bar / chain tight and rip the block through the side flat to the bar.
But now that I'm thinking about bendjoseph's saw its only a MS391.......I'm thinking about my 066 :D
Offline Al_Smith
Re: Bar Life?
« Reply #16 on: August 16, 2011, 06:16:15 am »
Well yeah but most people aren't going to pull the chain guard off to make a ripper .
Offline HolmenTree
Re: Bar Life?
« Reply #17 on: August 17, 2011, 12:43:28 am »
If I have 2 cords or more of firewood rounds in front of me to split.... I would. :)
Offline montreal
Re: Bar Life?
« Reply #18 on: August 17, 2011, 07:44:35 am »
Holmentree,thats a good ideawith losing the sprocket cover! I got thrown on the "flat to the bar'bit though,can u please describe that for a slowie,ta
Offline Al_Smith
Re: Bar Life?
« Reply #19 on: August 17, 2011, 08:59:51 am »
Running parellell to the round .It pulls big old noodles but cuts fast .
Problem being those stringy noodles will clog the clutch cover up with chips in short order .
Now way back when in the gear drive era many saws had no clutch cover but they didn't spin the chain at 65 miles per hour either .With a derail under certain conditions with no clutch cover you could get smacked with a chain,not good at all .
Saw Anywhere!
