Get your Forestry Forum Hats while they last!
Jarhead,I've come late to this conversation but may have something to add.Rebar.Log walls with log roof sitting on top of the walls. Rebar pin the roof logs to the wall logs. You can drill the logs, but make the holes 1/8th" smaller than the rebar. Then put a few layers of plastic on top. Ain't going anywhere.
Hey Jarheadi think we may have talked on the phone about this but may have been some one else that was doing the same thing.We built one into a hill side for my dad about 25 years ago.We used 12 inches of 2 inch washed drain rock as a base with good pine 3 by 12 "bull pen rails" as footing. we sprayed those with a wood preservative 5 or 6 coats and then used 2x8 PT pine on 12 inch centers with 3/4 inch PT plywood outside sheeting that ran down to the bottom of the 3"x12". we insulated to 6 foot below grade and lined with 3/8 spruce plywood. bottom 18 inches is not insulated or lined. We used 3/8 rebar as big nails for joinery at base and roof line. Cut to needed length and the pre drilled the holes to put them in place.3 rooms, front room is air lock and storage for containers used in the cellar and measures 4'X16' the 2 back rooms measure 8' by 8' (outside). One side is used for root veggies and such while the other side is used for canned preserves, ciders/juices, and wines. Roof is railroad ties set on edge with PT 1/2 inch ply wood on top and inside ceiling 3 sides and top of structure were wrapped in black plastic and then backfilled with a top side over burden that is settled to about 2.5 feet now. Vents are 4 and 6 inch PVC pipe with adjustable vent doors.Railroad tie retaining walls V'ed back at 45 degree angles to give a good working area out side the entry door with a good 12 inch deep 3/4 inch road crush apron to park/work on.
As you are off in the forest, it should be a good safe place for protection from a forest fire.
just a good steel exterior door with an extra lock or two.
Looks to me like you have it pretty much built in your head and I think it sounds about right. Over built is better then poorly built. One other thing for materials to use if available is Tamarack logs and lumber. Need to get that stuff in place ASAP after it comes of the stump but it will out last any thing treated that I have ever seen.I swear the stuff grows petrified.
