Paul;
I have been well pleased with the mill. The only parts I have replaced are the
2 bottom rail cam rollers, 1 band wheel belt, and one of the blade guide rollers.
I did rework the exhaust pipes and still need to do some more to them. The original
muffler had been replaced with the 2 samller mufflers and I found some original
exhaust pipes on e-bay that I will replace with. The 24 Onan engine is a later model
than the original. Idles a little rough but runs fine on fast speed. Probably needs a
carburetor cleaning. I, too, like the way the flipper clamp works. I didn't replace any
parts on it.
Here are some pictures of the flipper arm and spring:
And I also have a small extension to slip on the clamp in down position about 2 inches high:
I like using the hudrualics
_________________
Charles
