Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: pickens plan 3yrs later  (Read 9010 times)
Offline red
  • we will never forget
« on: July 13, 2011, 09:36:41 am »
t boones pickens is making the media rounds 3 years into the pickens plan
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline jdtuttle
  • If it's worth doin, it's worth doin right
Re: pickens plan 3yrs later
« Reply #1 on: July 13, 2011, 12:32:47 pm »
OK I'll bite  ;D What's the Pickens Plan  ???
jim
Have a great day
Offline Kansas
  • In the mountains of Kansas
« Reply #2 on: July 13, 2011, 05:56:32 pm »
A lot of it has to do with switching vehicles to natural gas. Its actually a good idea. Slight problem though; T Boon Pickens is heavily invested in natural gas. A whole lot of conflict of interest. Seems to me there was something about wind energy too.
Offline LOGDOG
« Reply #3 on: July 13, 2011, 09:33:22 pm »
Pickens was a little quick out of the gate. He didn't realize we'd have the collapse in the economy we did and then an Administration that's anti- natural gas and oil. The fact is though, Natural Gas is coming to a town near you on the automotive side. It's already here. We have several stations in the area. I took these pictures a few weeks ago at a station in town. Look at the prices and then compare it to what you're paying for Unleaded. The Flying J truckstops are putting in CNG pumps coast to coast. There will be stations in every one of the lower 48 states.  :) Chesapeake energy just made a big investment in the process as well. $150 Million I believe. I'll have to pull the article up again.
Here are the prices:
Here's what the pumps look like:
Here's what the fill nozzle looks like. Notice the 3600 psi.
Here you can see the price and how it's sold. PPGE = Price Per Gallon Equivalent.
Saudi Arabia just spent something like $180 Billion to begin switching their entire economy over to Nat Gas. Now, why would the country who is sitting on 250 Billion barrels of oil reserves decide to do that at this particular moment in time? Why would the majors in the USA be buying up all the Nat Gas reserves they can from smaller independent producers? There's a reason.  ;)
Offline Ianab
« Reply #4 on: July 13, 2011, 09:55:42 pm »
CNG works OK as a vehicle fuel, NZ had a lot of cars running on it a few years back (later 70s, early 80s). But it does have a few down sides. The tanks are heavy for the amount of fuel they hold, and that limits the range between fill ups. And the CNG inherently has less power. Unless the engine is running a turbo and you can adjust the boost, you will notice a drop in power. You can't just adjust the mixture like Ethanol, and get the power back by a bit burning more.
Apart from that, it worked, and the conversion doesn't loose the petrol fuel system, so you can change back with a dashboard switch if you are on a trip away from the filling station. Fuel economy was pretty good at low speed, better than petrol as the fuel is injected as a gas, and mixes properly, even at low revs.
But LPG (propane) is a better option for cars. The tanks aren't high pressure, so they are lighter, and hold a similar fuel equivalent to petrol. LPG conversions are still sold here, but mainly to delivery drivers and taxis, where the high mileage means they save enough to make the cost worthwhile. I think Ford Australia is building cars with dedicated LPG systems from the factory.
Weekend warrior, Peterson 8" WPF with Stihl 090 powerhead, Dolmar 7900 and Stihl MS310 saws and  the usual collection of power tools :)
Offline Brucer
  • The Kootenay Sawyer
« Reply #5 on: July 14, 2011, 02:19:56 am »
A bit of possibly useful trivia for you. There's a series of chemically related hydrocarbons known as the "parafin hydrcarbons". You'll recognize some of them for sure.
NAMEMol WtBoiling TempDensity Liq pressure
Deg Cg/ml PSI
Methane16-1620.00072gas1000+
Ethane30-880.0014gas600+
Propane44-420.002gas40
Butane58-0.6***gas3
Pentane7236.62liqN/A
Hexane86690.66liqN/A
Heptane100980.68liqN/A
Octane1141260.70liqN/A
Nonane1281510.72liqN/A
Decane1421740.73liqN/A
Notice how every column follows a trend. Boiling temperature increases, Density increases (and makes a big jump when the gas is normally liquid. Note in particular how the pressure to liquefy the gases drops.
It only takes about 40 PSI to liquefy propane, so a metal tank with relatively thin walls will do the job. And it only takes 3 PSI to liquefy Butane, which is why you can use plastic in a disposable lighter.
Natural gas is made up of Methane and Ethane. It's not worth trying to liquefy it for vehicle use -- the containers would be way too heavy.
These numbers are rounded off. I will see if I can add to the table in the next couple of days.
Bruce    LT40HDG28 bandsaw with two 6' extensions, ED22 twin blade edger.
Offline WildDog
« Reply #6 on: July 14, 2011, 04:19:33 am »
Quote
Your right there, back in 2003 we bought 10 Ford utilities that were dedicated LPG. I am no mechanic but opperationally I couldn't tell the difference.
I'm not below you, I'm not above you, I'm right here beside you.    JD 5510 86hp 4WD loader Lucas 827, Pair of Husky's 372xp, 261 & Stihl 029
Offline red
« Reply #7 on: July 14, 2011, 06:23:50 am »
we have a natural gas line in the street and there is a pumping station available for the garage cost about 3000 but only new car is honda for 27000 flea bay has some used fleet vehicles but i was told tanks usualy need to be replaced
Offline Kansas
« Reply #8 on: July 14, 2011, 06:34:19 am »
There has been a refueling station for years in a small city near me. Farmers have used natural gas on irrigation pumps where its available, also some use propane.
Didn't realize the flying J truck stops were all putting it in. You can bet the big truck lines will be converting. No good reason not to. Guess Detroit is coming out with some cars before long as well.
Offline LOGDOG
« Reply #9 on: July 14, 2011, 08:54:52 am »
Yep, check out this company called Westport: http://www.westport.com/
They're a leader in producing Natural Gas engines. Almost all of Chesapeake Energy's fleet of pickup trucks here run on CNG. Our municipalities have changed over and bought buses that run on CNG. Next are the Garbage trucks. They apparently are some of the least efficient users of fuel historically.
Read this article: http://www.chk.com/news/articles/Pages/1583997.aspx
That's the Chesapeake investment article I spoke of earlier. $155 Million investment in the next three years to build out LNG fueling infrastructure along Interstate Highways for Heavy Duty Trucks. Awesome!!! With plans to invest $1 Billion over the next 10 years. I believe Encana is working on something similar. Down here, Encana is also partnered with Shell Oil.
It's coming. T. Boone was a tad early, but it's better to be early to the party than late. Might take a strong stomach depending on the timing but the case for Natural Gas is certainly there. The Natural Gas play that we're sitting on top of produces more Natural Gas on a daily basis than the Gulf of Mexico. I read that the other day.
The price for CNG I posted above .... CNG was about half that much at 87 cents ppge up in OK around the same time. That's cheap fuel.
Offline Kansas
« Reply #10 on: July 14, 2011, 09:22:04 am »
I am surprised railroads aren't switching to natural gas. I know they dabbled in it years ago. With the price difference between that and diesel, and their infrastructure, seems like it would be natural to switch over.
One thing I do wonder about though. If in 5 years a lot of over the road trucks are switched along with local route trucks, will the price go up to negate the advantage? Too many variables, not knowing what diesel would be priced at in 5 years. I also don't hear much anymore about that natural gas pipeline from Alaska. They got tremendous reserves up there.
Offline doctorb
« Reply #11 on: July 14, 2011, 10:22:14 am »
I am pretty ignorant about this stuff.  Thank for the posts and the links.
How do thin-walled propane tanks hold up in vehicular accidents?  For all the fake explosions we see in car crashes on TV, we don't have too many explosions with gas powered vehicles in real life. (Remember the Pinto!)
Offline LOGDOG
« Reply #12 on: July 14, 2011, 11:55:29 am »
Yep, railroads have my interest as well. I think it's just a matter of time. Railroads are already a very efficient way to move a lot of freight even using today's diesel engines.
And you're right, with increased demand price will go up on NG. But right now 1 MCF or 1000 cubic feet of NG is the equivalent of almost 8 gallons of diesel. (I think that's what T.Boone said a few weeks back.) So 1 MCF of NG right now costs $4.39+/- and 8 gallons of diesel would cost me $30.00 at $3.75. So $4.39 vs. $30.00 .... there's a ton of room for inflation in NG. The par value of NG to Diesel currently is $35.12/MCF minus the appropriate road tax for your state. Lots of room to run.  :)
But let's say that it was a break even. Par. At least we'd be spending those dollars in America and creating U.S. jobs vs. buying that much more foreign oil and sending our money overseas. That gets us nothing.
I've had the explosion question in my mind as well. I haven't seen a ton of talk about it. I do believe the flash point of NG is substantially higher than unleaded though. I want to say NG is like 1200 degrees and Unleaded maybe 600 for a flash point. I'd have to double check.
Offline red
« Reply #13 on: July 14, 2011, 12:39:09 pm »
thats what it is about keeping fuel dollars in the usa not overseas not perfect but another option
Offline submarinesailor
  • LT15, F250 SD 6.0L diesel, and a wife of 38 yrs
« Reply #14 on: July 14, 2011, 01:06:00 pm »
I did not know what the CORRECT/FORMAL definition of Flash Point was, so I Wikipedi it and here is what they say:  The flash point of a volatile liquid is the lowest temperature at which it can vaporize to form an ignitable mixture in air. Measuring a liquid's flash point requires an ignition source. At the flash point, the vapor may cease to burn when the source of ignition is removed.
The flash point is not to be confused with the autoignition temperature, which does not require an ignition source.
The fire point, a higher temperature, is defined as the temperature at which the vapor continues to burn after being ignited. Neither the flash point nor the fire point is related to the temperature of the ignition source or of the burning liquid, which are much higher.
Wiki has the flash point of gasoline as -43 C (-45 F) and the autoignition temperature as 246 C (495 F). The flash point of natural gas is -188 C (-306 F).  It becomes explosive between 5-15%.
I had an idea of them, but I like the fact that they seperated the 3 different type of points: Flash, autoignition and fire point.
BTW - the official number of gallons of diesel fuel per mmBTU (approximately equal to an MCF) is 7.19 gallons (138,960 BTUs per gal)
Bruce
Offline LOGDOG
« Reply #15 on: July 14, 2011, 01:15:19 pm »
Good stuff Bruce. You left out the autoignition temp on NG though. Do you have that off hand?
I like that they break it down into the three categories as well. It's a more specific way of addressing potential scenarios.
My neighbor works for Centerpoint Energy  and has for the last 30 years. We were discussing some of this the other day. He's actually done quite a few conversions with success.
Even at 7.41 to 1 it looks good next to Diesel. Adjust the above numbers by 6/10 of a percent.  ;)
Offline LOGDOG
« Reply #16 on: July 14, 2011, 01:25:38 pm »
http://www.engineeringtoolbox.com/fuels-ignition-temperatures-d_171.html
Looks like autoignition temp on NG/Methane is 1076 F .
Offline Al_Smith
« Reply #17 on: July 14, 2011, 01:36:37 pm »
Couple of things on this .Maybe 20 some years ago there was push to convert service type vehicles to propane .Supposed to be cheaper but as so stated they didn't have the power as with gasoline .
While at one time farm tractors used in the southern part of the US were propane burners but it didn't work so well in the north .During cold weather the regulaters would malfunction .
Now they may have remedied that situation but so far you don't see many propane equipted service trucks in this area  because of the problems of the past . What you do see is propane fork trucks and like vehicles that are used for in plant industrial usage .Almost nothing is use on the outside .
Now Pickens and his gas evidently failed to mention that the natural gas consortium also has had so called "shortages " in the past .Weather the were man made or true noone is fessing up to . Kinda like OPEC with different players in my opinion .
Offline LOGDOG
« Reply #18 on: July 14, 2011, 01:57:43 pm »
Al ... when were the shortages? Prior to 2008 I'm guessing when every Natural Gas Shale play in the world came out of the woodworks? We've got hundreds of years worth with just what we have in the USA.
I also wanted to mention that there are NG reserves that are currently not being tapped because they're not economical to drill. They require NG to be at maybe $7-$10/mcf. So as the price goes up more supply will come on line because it will make sense then.  :)
« Reply #19 on: July 14, 2011, 02:07:08 pm »
I just reading a piece yesterday that stated there is about 450 TCF of recoverable gas that this time.  But if prices were to increase to about $8.00/MCF the number goes to about 705 TCF.  And As I have said before, all these numbers do not include the methane hydrates (http://en.wikipedia.org/wiki/Methane_clathrate) located all over the place.
BTW - Your comment about your neighbor working for CenterPoint Energy, reminded me I needed to call one of my POCs that CenterPoint Enrgy.  Thanks for the reminder. :D :D :D :D :D :D :D :D
Saw Anywhere!
