Get your Forestry Forum Hats while they last!
(Image hidden from quote, click to view.)We had the same question and got all kinds of answers. We went ahead and put sheet metal right over the shingles using longer screws. It looks great after 4 years. We roofed another couple more sections of roof this spring - again, right over the shingles. But we have one more major section of roof to do that has a long span. We will probably remove the shingles just to save weight.They do make as special and pricy rubber sheet to put down under the metal. But we opted not to use it.One tip I've learned to make the roof look better is to layout and pre-drill the screw hole before putting it on the roof. Leave them in a stack and that way the screw heads will all line up.
Glad to see this topic, as I am goning to be in this boat pretty soon. So lets hear some more pros and cons...Tim
I am also getting a metal roof installed. The roofer is planning to put down 1x4 nailers over the singles. He said the air space helped cool the roof, and in Georgia, that is a big deal.
I suppose it could be a regional issue, but the supplier where I buy most of the metal I use voids the warranty if it’s placed directly over asphalt shingles. It also voids the warranty if you cut the metal with a saw. Five to ten years is only 10-20% of what is advertised to be a fifty year product. I guess time will tell who’s right, but I will continue to use the foam not only over shingles, but under any metal roofing it also prevents condensation problems.
A builder friend of mine told me to lay down felt paper over the shingles so they can't make contact with the metal roofing, so that is what I did. However, after reading the responses to this thread and sitting here thinking about it, I don't think that was nessessary. How much and how fast does the metal roofing move? I think it would take a very long time for the shingles to wear through the metal.
