Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Solar Kiln Build #2  (Read 3811 times)
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
Solar Kiln Build #2
« on: May 09, 2011, 10:46:31 pm »
Well after about a week with some rain involved, I have this much done. Been a little slow for a one man show but its going ok.
Offline WDH
  • April 1998 - August 2008
Re: Solar Kiln Build #2
« Reply #1 on: May 09, 2011, 10:53:03 pm »
I like it so keep the pics coming.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline fishpharmer
« Reply #2 on: May 09, 2011, 11:02:14 pm »
Your off to a good start.
What are the dimensions of this new one?
I built my own band mill with the help of Forestry Forum.
Offline Bill Gaiche
« Reply #3 on: May 09, 2011, 11:21:16 pm »
Outside dim. are 12'x6'. bg
Offline fishpharmer
« Reply #4 on: May 09, 2011, 11:25:05 pm »
Thanks.
Offline Planman1954
« Reply #5 on: May 10, 2011, 09:41:52 am »
That looks great. Where are you going to get the panels for the top?
Norwood Lumbermate 2000 / Solar Dry Kiln
Offline Bill Gaiche
« Reply #6 on: May 10, 2011, 06:00:45 pm »
Planman1954 , as of now I guess Lowes. Tuftex PolyCarb. Its good for temps of -40 to 270 degrees. About $28.00 each. I have to have the 12' ones. They come in 8' and 12 '. To bad not in 10'. bg
Offline laffs
« Reply #7 on: May 10, 2011, 06:54:26 pm »
looking good Bill , let us know how much time & $ you have tied up in it
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
Offline Bill Gaiche
« Reply #8 on: May 10, 2011, 08:44:14 pm »
laffs , thanks, I will try and keep track of cost and time. bg
Offline Larry
« Reply #9 on: May 11, 2011, 10:58:10 am »
I used Lowes fiberglass panels.  17 years later they are still in good shape.  The new owner uses it for a garden shed.
For the inside layer I used 6-mil poly.  The idea of insulating the roof is great but the choice of poly on my part was poor.  I had to replace it every year or so and it was a pain.
Larry
Nine out of ten trees recommend wood for your building project.
Offline Piston
  • ...Brick by brick my friends...brick by brick!
« Reply #10 on: May 11, 2011, 11:06:25 am »
Lookin good so far!  How did you figure the angle of the front/roof?
“What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race.”
Offline Bill Gaiche
« Reply #11 on: May 11, 2011, 05:54:12 pm »
Thanks guys. I did the angle thing the hard way. Dont know anything about rithmatic. I built the south wall the heigth I wanted, then set a 45 degree square on top of wall and streched a string up till it interceted a temperary north wall stud and made a mark at the top. Poor boys have poor ways but it worked. I have the siding on south, east and west wall now. I am going to use treated plywood on north wall so that it will give more strength in mop to support the doors which i feel will be pretty heavy.bg
Online LeeB
« Reply #12 on: May 12, 2011, 12:00:38 am »
I haven't researched solar kilns in a good while, but I think the collector angle is supposed to be fairly close to your lattitude, ie. if your lattitude is 54^ then your pitch should match in order to collect the most sunlight.
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 1966 Chevy C60 w/ dump bed.
Offline ely
« Reply #13 on: May 12, 2011, 08:50:42 am »
looks great, that is something i need to do for myself. was there a thread on solar kiln #1?
Offline pineywoods
« Reply #14 on: May 12, 2011, 09:19:18 am »
re collector angle.. The optimum angle will vary depending on lattitude, season and even time of day. 45 deg is a good compromise. I use corrugated netal, again a compromise, but most of all that's what I had handy... ::)
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline Bill Gaiche
« Reply #15 on: May 12, 2011, 01:51:34 pm »
ely, there really wasnt a #1. I just called it #2 because (Planman1954) had already started his about the same time I started mine. He has a thread on his. Just thought I would keep it seperate from his so we didnt get confused. So at least that I dont anyway. bg
Offline Bill Gaiche
« Reply #16 on: May 18, 2011, 10:07:15 pm »
I have gotten a little more done. The rains has slowed things down some. Rained this morning, again tomorrow morning and on Friday. This where I am as of today. bg
Offline thecfarm
« Reply #17 on: May 19, 2011, 11:22:57 am »
Looks good.
Larry just an idea,IF you do it again,would greenhouse plastic work? We still have some on a small one that is 6 years old. Probaly kinda cloudy now,but for what we need it's fine.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline Handy Andy
  • Location: right on the edge of the great american desert
  • I'm not new anymore
« Reply #18 on: May 19, 2011, 11:47:11 pm »
  Couple questions, did you put posts in the ground, or does the kiln sit on the ground? And how do you plan to insulate your doors.  Is the poly double wall or single? Sorry, that was 3.
My name's Jim, I like wood.
Offline Bill Gaiche
« Reply #19 on: May 20, 2011, 09:49:56 am »
The kiln sits on 4 3"x6" beams which sit on 12 concrete blocks. Doors will be insulated just like the rest of kiln, 6" in the floor and 3.5" in all the walls. Will use one single sheet of  Tuftex PolyCarb.
Saw Anywhere!
