my stihl chainsaw will foul a plug, any brand if you look at it wrong. it needs some carb help. my honda tiller motor has a float stuck in it, it fouls the plug also.
we have a welder with a red seal engine on it, at times it will foul all the plugs at the same time, same with the 300 international tractor. the problems all come from the carbs dumping too much gas.
i also have a 175 hp evinrude that will foul a plug or two every now and then. but i think its because the coils drop out on it.
i use boshe in the saws and ngk in the boat and atv.
