Good point on the front ballast required. I was planning on adding Rim Guard to the front tires and even hang a couple of suitcase weights. Manaul says back lift is 7,900 lbs but I also read somewhere that the proper ballast is required especially without a loader. In this case will go very slow with this approach and will double check with the local dealer on the required ballast given what I would like to lift.
