Get your Forestry Forum Hats while they last!
That Hart interface completely controls the amount of discharge and will shutdown the inverter at a set voltage level. I can't remember the setting, but I think it is either 10.0 or 10.2 volts which allows use of some percent of capacity. Discharging below that level will shorten the battery life. But I never do that because it automatically dumps the load at the set level.
So what kind of life are any of you other off grid people seeing from your battery banks and what kind of batterys are you using?
Some chargers have a de-sulfation charge option, which is a controlled overcharge.
With four Trojan T-125s connected as a 12 volt system, you would have a maximum capacity of 480 amp hours. Real camping numbers would look more like ((90%x480) x 40%) = 172 amp hours of storage capacity.
Quote from: Dean186 on April 05, 2011, 11:28:55 amSome chargers have a de-sulfation charge option, which is a controlled overcharge.I thought that was known as an "equalization charge". The chargers I've seen that do de-sulfation use a "pulse" technology...But I have to admit, I have little direct experience with this... just some reading, an dmuch of that was a couple of years ago.
Quote from: John Mc on April 05, 2011, 02:52:36 pmQuote from: Dean186 on April 05, 2011, 11:28:55 amSome chargers have a de-sulfation charge option, which is a controlled overcharge.I thought that was known as an "equalization charge". The chargers I've seen that do de-sulfation use a "pulse" technology...But I have to admit, I have little direct experience with this... just some reading, an dmuch of that was a couple of years ago.John Mc, You are right; the equalization charge is essentially a controlled over charge and not de-sulfation. Desulfation uses high frequency electronic pulses. My MPPT solar controller in my camper provides an equalization charge and not a sulfation option.Both equalization and desulfation can prove beneficial for flooded/wet cell batteries. One should not equalize gel or AGM batteries.
DBHow about if we just hear your opinion and let it go at that?
