Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Would you saw for .10 a board foot???  (Read 2480 times)
Offline gator gar
« on: March 23, 2011, 10:12:01 pm »
I did.... Actually, I resawed some 12x12x12s, down to an inch and 7/8s x 12. That was 2.40 a board and I cut 138 of them,before it was all said and done. Not too bad.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Would you saw for .10 a board foot???
« Reply #1 on: March 23, 2011, 10:27:55 pm »
do you pay for equipment and maintenance?
Or do you get paid $0.10 to run your own equipment?
I wouldn't saw lumber on my equipment for $0.10/bf
lots of dull bands and chains
Offline gator gar
« Reply #2 on: March 23, 2011, 10:34:36 pm »
You wouldn't be counting that 330 dollars that I put in my pocket either. I was already set up and I just went with it.
Offline Bandmill Bandit
« Reply #3 on: March 23, 2011, 11:04:10 pm »
its jobs like that that take wear and tear out of everything that shows up in other jobs and end up costing you a lot more then the 330 cash you put in your pocket at the end of the day.
Some times you get lucky but it is tat-amount to playing Russian roulette.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
Offline Brucer
  • The Kootenay Sawyer
« Reply #4 on: March 23, 2011, 11:07:48 pm »
I charge $0.15 per BF for resawing, provided the timbers are clean, don't need squaring up, and the customers knows exactly what he/she wants before I start cutting. Otherwise it's by the hour. I base the BF charge on the nominal size of the original timber, not on the product.
Bruce    LT40HDG28 bandsaw with two 6' extensions, ED22 twin blade edger.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #5 on: March 23, 2011, 11:10:29 pm »
Even the Amish charge more than that.    ::)    And that looks like a manual mill?  At $330 in you pocket you're still losing money.  :-X
Hidden Acres Farm
I got a shotgun, a shovel backhoe and 57 acres!
Wood-Mizer LT40HDG25
Offline clay3
« Reply #6 on: March 23, 2011, 11:27:41 pm »
I"d take all of that I could get.
Offline r.man
« Reply #7 on: March 23, 2011, 11:31:19 pm »
If you are happy with what you got paid for the job I think that that is the important thing. It is hard to judge every job from the standpoint of piece price without knowing all the other factors.
Online tyb525
  • Always learning.
« Reply #8 on: March 23, 2011, 11:49:28 pm »
Just remember, charge what you need in order to make a profit, and someone will pay it if you have good quality. Just because someone will pay you $.10 to do that, doesn't mean they wouldn't pay $.25.
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline Ianab
« Reply #9 on: March 24, 2011, 01:50:23 am »
I think if you worked it out as an hourly rate charge he was doing pretty well, maybe $100 an hour?
If you can earn $100 an hour with a manual mill you are doing pretty well.
No opening cuts, no turning of logs or cants, no edging, less band wear with no dirty bark. Just $2.40 each time he goes up and back. Big boards like that can add up a LOT of bd/ft per hour.
It's fair for both parties if you charge an hourly rate for non-standard jobs. Resawing, undersize or oversize logs, or any non-standard sawing. In that case, work out your hourly rate, probably based on if you were cutting normal logs at 20-30C bf/ft and charge that. If the customer had wanted them cut into 1" boards, it would have taken twice as long, and he would have paid twice as much. If he wanted them simply sliced in 1/2, taken 1/2 the time and probably only paid 5c per bd/ft !!!
Weekend warrior, Peterson 8" WPF with Stihl 090 powerhead, Dolmar 7900 and Stihl MS310 saws and  the usual collection of power tools :)
Offline Meadows Miller
  • The Walkabout Sawyer
« Reply #10 on: March 24, 2011, 04:25:47 am »
Gday
You said it all when you said your not counting that $300 in My pocket  ;) I bet you did not burn more than $30 bucks worth of fuel for the day and only used 2 Maby 3  fresh bands sawing that order Mate thats 3000 bft (7.07 m3) sawn roughly which is pretty good going  ;) ;D how long did it take you to do it start to finish Mate  ???
say it took a day say $40 worth of imput costs  minus say $10 for the payment on the mill (the wear n tear on the machine would be bugger all !) so $250 gross for a days work still aint that bad Boys  ;) and a hell of alot better than working in a bloody office  ;) :D :D ;D 8) 8)
Regards Chris
Jackson Lumber Harvester RMP 50" Manual Circular Mill #132 with Jackson Lumber Harvester Portable Edger, Meadows #2 delux manual circular sawmill & Edger, 1997 International 4700 Flatbed
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #11 on: March 24, 2011, 05:25:39 am »
I routinely saw logs to lumber for $150.00/1,000bf.
So, it looks like you have done good for a days work.
Overall, the price usually depends on what part of the country you're in!
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline clousert
    • Clouser Farm - Lion Country Bandsaws
« Reply #12 on: March 24, 2011, 06:53:46 am »
It all depends on how much you want the job, and what that job is interrupting for you.  We saw pallet logs mostly, so there are always logs on the dock and partial lumber piles being built.  Custom orders actually SLOW DOWN our production, due to log change/out, starting new lumber piles, sawing odd sizes for the customer, and dealing with the customer, and not knowing for sure if and when they will even return to pick up their lumber and/or pay for it.  As a result, we charge 25 cents a bf or $40 per hour, depending on the job.
Tom Clouser, farmer and sawmill operator in Pennsylvania, partner of CLOUSER FARM ENTERPRISES
Online ellmoe
« Reply #13 on: March 24, 2011, 07:22:15 am »
   What did your per hour rate equal?
Mark, Wildlife Biologist (in my previous life), now 2 HD40E25's, Weining Promat, Koetter Kilns (2), Sore back and arthritic fingers!
Offline gator gar
« Reply #14 on: March 24, 2011, 07:30:33 am »
I make 30 an hour in the refineries as a pipefitter. I would cut 4 to 5 of these per hour and off load them on the side of the mill, 3 wide and 12 high. Just basically letting them slide off the bedrails. So that comes to 57.60-72.00 and hour. Not bad at all in my book. I was waiting on the loader too, in between cants.
Ya'll don't underestimate my manual mill. It has a 25 horse on it, with the power feed, just like the LT40. It does pretty good. I would do this all day long, everyday, if I could.
Offline ladylake
« Reply #15 on: March 24, 2011, 07:42:52 am »
 Nothing wrong with $60 a hour, then figure in all the cash money (I alway send half to Uncle Sam, right) and tax deductions .   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline laffs
« Reply #16 on: March 24, 2011, 06:59:00 pm »
me too
timber harvester,tinberjack230,34hp kubota,job ace excavator carpenter tools up the yingyang,
Online ellmoe
« Reply #17 on: March 24, 2011, 08:52:52 pm »
I. I would cut 4 to 5 of these per hour and off load them on the side of the mill, 3 wide and 12 high. Just basically letting them slide off the bedrails. So that comes to 57.60-72.00 and hour.
   I thought that your per hour rate would sound a whole lot better than the bf price. Resawing wide , clean cants is very different than sawing logs. Ya done good! 8)
« Reply #18 on: March 24, 2011, 09:34:30 pm »
It's situations like that, that make it impossible to assign one price that fits every situation.   What you have to be careful with is not that this fellow remembers your price and wants the same deal on a different type of job, but that your other customers don't find that you sawed Mr. X's wood a lot cheaper than you sawed theirs.   Sometimes it goes a bit deeper (business-wise) than how much money you can clear because you are already set up.
Offline gator gar
« Reply #19 on: March 24, 2011, 10:36:39 pm »
You are exactly right Tom.
Saw Anywhere!
