Get your Forestry Forum Hats while they last!
There are 2 small plastic tabs on the back side of the slide portion of the switch. When 1 of them brakes the switch stops working. You can reinstall the slide portion upside down with the 1 good tab still intact and the switch will work ( until the other tab brakes ).
Yes, on both of the 372XPs I have the switches are bad. A friend who has a bunch of them the switches are always going bad. I installed a toggle switch on mine.
Had an interesting thing happen today. Since I had the saw torn down to change the fuel line I really blew the switch off with compressed air and noticed that the wire connectors seemed kind of loose on the tabs. So I grabbed the needle nose pliers and closed up the connectors. Today the saw stop switch actually worked. I am wondering if the issue is that the voltage is low enough going through the switch that when the connection loosens a little the switch doesn't work.??
Why not just solder the wires to the switch?
