Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Carb Hi and Low Screws keep vibrating loose.  (Read 1813 times)
Offline Cut4fun
Re: Carb Hi and Low Screws keep vibrating loose.
« Reply #20 on: March 21, 2011, 02:04:30 pm »
The set I know of.
Learn Chainsaw Repair ChainsawRepair
Offline John Mc
« Reply #21 on: March 21, 2011, 02:18:55 pm »
What a pain in the rear-end! Why can't they just stick with the standard screw driver? Do they really think that's going to stop someone intent on adjusting the mixture?
I heard someone mention that some size or another of plastic/rubber tubing works well on the splined screws... not that I'm likely to have the right size lying around anyway.
Small time fire-wooder in a neighborhood cooperative.
Offline Cut4fun
« Reply #22 on: March 21, 2011, 03:07:52 pm »
The D was on my Solo. I just cut slots.
The spline became a pita when doing a bunch over and over with plastic tubing. I broke down and got the spline screwdriver. Saved a lot of time in the end when doing 3-4 poulans in a row.
Offline 05_sprcrw
« Reply #23 on: March 21, 2011, 04:40:37 pm »
I have now have 3 out of the 4 I am just missing the D set. It sure makes things easier even though like others said you can get by with out it if you want to.
Offline JohnG28
« Reply #24 on: March 21, 2011, 06:40:41 pm »
That's the tool I would need for my little Husqvarna 142.  A while back before I realized they couldn't sell this tool I had a dealer recommend using a piece of fuel or impulse line to do the trick if adjustments were needed.
Offline Yoopersaw
« Reply #25 on: March 22, 2011, 04:32:29 pm »
Where can I pick up a set of these?
Offline Cut4fun
« Reply #26 on: March 23, 2011, 06:46:47 am »
FEEbay for the whole set.
Offline 05_sprcrw
« Reply #27 on: March 23, 2011, 08:09:21 am »
Like someone said ebay you can get the single driver or the complete set very reasonably.
Offline 05_sprcrw
« Reply #28 on: March 30, 2011, 09:49:32 am »
Well I got the driver in and it is too small for the throttle adjustment on the 394/395 so I am going to end up just making on myself and see how that goes. A pair of long needle nose pliers can probably get in there and turn it with the rubber boot on but I am going to try this more because I can then any other reason.
Saw Anywhere!
