Doc -
Have you considered Solar Hot Water? There are some decent systems out there where they use a couple solar hot water panels to preheat a holding tank. On sunny days, this preheat tank is hotter than your main hot water tank. Even when partially sunny here in VT in the winter, it will preheat your water at least partway, so you are not refilling your hot water tank from 50˚ water from the well. You keep whatever is heating your domestic hot water now, but it only kicks on when there is not enough sun to stay ahead of your usage.
Plumbing is very simple. You just break into the cold water feed line to your hot water system and feed from the preheat tank. If you have a south-facing roof with decent sun exposure, you can mount the panels on it. Alternatively, you can mount them on a rack near the ground.
There are a number of companies selling pre-packaged systems that are fairly easy to install. Lots of folks "do it yourself", but if you are not comfortable with that, the prepackaged nature of the system makes it a snap for any plumber to hook up the system.
Here's the link to a supplier of prepackaged systems near me that ships nationwide:
http://www.gosunward.com One of the options I really like is a "timber-frame" like ground mounting rack that can easily by finished into a playhouse, tool shed, chicken coop, etc. I'm debating between that and mounting on the roof of my garage.
Their systems is eligible for a 30% federal tax credit (that's a CREDIT, not just an income deduction). Many states also offer incentives for these renewable energy systems. I'm not sure if MD does or not.
John Mc
