Get your Forestry Forum Hats while they last!
Thanks for the videos. Well done.(and more thanks for not adding music, and just leave the sounds of the machines working )
Thanks for posting its fun to watch a Harvester work, it sure takes the work out of it.
Nice videos. It's a familiar look as I run one of those Ponsse Ergo's.How are you running your softwood thinnings? Are you marking trees or leaving it to the operator to select? And to what basal area did you thin that pine stand to?The MN DNR has reluctantly learned to leave softwood thinnings for operator select now though I just moved into an older sale that was semi marked and very poorly at that.
Quote from: lumberjack48 on February 23, 2011, 02:21:13 pmThanks for posting its fun to watch a Harvester work, it sure takes the work out of it.It does take the hard physical work out of it but after sitting in the relative comfort of those cabs for 8-10 hours, you will be physically worn out. The constant attention to everything and constant motion takes a toll on you for sure.
It's not something I would consider with my own consultancy as I run a top quality service that caters to those who expect me to deliver what I sell.
That's a very good thing but that would put your jobs at odds with my own personal beliefs as I run a very high quality service too and treat every stand as if it is my own.
In 1st thinning in pine plantations I cut one row and thin two on each side of the removed row selecting worst first and then other quality factors and tightest spacing next. In later thinnings I cut worst first and consider spacing as next criteria. In my experience I cannot do as good a job with marked stands and will not cut them and most of the better loggers have come to the same conclusion.
The job I just started cutting is a good or bad example, depending on your view. I am removing all the aspen and most all the balsam. Plus thinning a red pine stand. But there overmature aspen that I cannot get to because it's mixed in with some white spruce that missed getting marked. And the south half of the sale the forester marked the merchantable balsam and then got tired of the marking and on the north part he said to cut all merchantable. But he marked the balsam, red pine, and a few spruce with one red dot on one side of the tree and it's impossible to see the markings even when you approach from the right direction.
And the forester that marked the sale is from the main office and the forester working the job does not want to change anything as he said if I cut something I should not it's a misdemeaner but if he allows me to cut something I am not allowed to cut for him it's a felony.
My only excuse for cutting this sale is I bought it some 5 years ago under different circumstances and haven't been able to cut it before because of poor market conditions.
On our thinning crews, we use operator select on our land in the South. With good training, experience, and good feedback, the cutter operator does a great job. Much depends on the skill and mentality of the operator. We thin hundreds of thousands of acres per year, so these guys get very good.
Quote from: WDH on February 23, 2011, 08:33:47 pmOn our thinning crews, we use operator select on our land in the South. With good training, experience, and good feedback, the cutter operator does a great job. Much depends on the skill and mentality of the operator. We thin hundreds of thousands of acres per year, so these guys get very good.I know both of the harvester operators in my videos personally. Finding a dinged up tree in those operations is like finding a needle in a haystack. Seriously. I will put our quality Michigan logging contractor skills up against any in the entire world (with the exception of specialty operations such as cable/high line/heliops, etc.) . They are THAT good! WDH, I've assisted clients with timber sales as a consultant in 3 states, assessed forests professionally in 7, including some in the Southeast on both public and private lands and unprofessionally in most of the others. I've seen the good, the bad, and the ugly. I know there are some super skilled logging contracting personnel all around the country. However, every time I have come back to Michigan from out-of-state projects, I count my blessings to have the level of skilled operators we have here. There are certain places around the country that I could absolutely NOT say that for - I will not be mentioning those here however. i have been trying real hard not to respond to this. if i got this right most loggers are dirty rotten stinkers........unless there are from ...michigan? i think gary an i agree neither one of us would cut your painted wood
Mr. Kegerreis, I see your greater then thou attitude and social skills have not improved over your absence from the forum. You sure have a way of grinding people the wrong way, which in turn grinds me the wrong way.
I have all of our old communications, I have the letter that Tom sent to you on November 12, 2007 on how you conduct yourself on this forum and alienate not only the membership, but for a fact, potential colleagues. The one he sent that caused you to bow out the first time. Would you like me to post that here for you to refresh your memory?
I'm going to tell you one time here. Become a sweeter more lovable you and figure out the fact that the combined knowledge of the membership here makes you look like an ameba no matter how high you regard yourself.
