Get your Forestry Forum Hats while they last!
how small?? bar saw may not need as much as circle saw. job i hauled off from yrs ago had a hood crane big 28000 series maybe. had a big pump for just the saw cause the saw turns all the time. the flywheel efect helps keep it going. the hood worked great in sp fir hard wood it slowed down. next problem you will have is heat pumping more oil = more heat. got an oil cooler on yours?? youll need one big one. dont know if you want my advice ......but your gona get it. you always cut hard wood like in your pics?? ditich the truck the crane the skidder buy a fowarder. have one good cutter work with you . find someone to haul your wood your not making a nickle with that truck. if you got wood on the ground you can yard it with a fowarder you can work in the rain snow or after the sun goes down
You wont find a forwarder for 100 miles of these parts. I dont know what kind of conditions you work in but around here its mostly small select cuts .Land owners dont want them around. To much damage to the forest. You dont even see swing grapples for the same reason. That why small cable skidders are so popular in appalation hard wood country.
