Get your Forestry Forum Hats while they last!
The post on top of the tie beam would now be a king post right? So aren't king posts in tension?
... If the load on the beam is greater with a lower pitch then wouldn't the pitch be included in the calculation? And if the pitch must be included calculating the load on the ridge beam, then shouldn't it also be included in calculating the load on the rafters? This is starting to make my head hurt. So what is the standard way to calculate the load on a supported ridge beam and rafters if the pitch is directly related to the load?
The post on top of the tie beam would now be a king post right? .....Rusty
