Get your Forestry Forum Hats while they last!
Actually hope some of you folks post projects as well..especially if you have one of these!
My old 2094 is overhead in the woodshed. It blew a crank seal and I needed a saw so I got a 395XP. Maybe someday I'll get it fixed It was the 1st my local J-Red dealer sold. He was going to make me a deal on a 930 but I knew what I wanted
You better dropstart that sucker about 90 miles an hour or it would just buck back at you. Then when you shut it off, the rope pulled into the housing with a big thwack. You had to replace the starter rope every couple of weeks. I don't remember if they ever came up with a fix for that.
I had those old Jonsreds, too. A couple of 920s, but before that a 90 that pull started like a V8. You better dropstart that sucker about 90 miles an hour or it would just buck back at you. Then when you shut it off, the rope pulled into the housing with a big thwack. You had to replace the starter rope every couple of weeks. I don't remember if they ever came up with a fix for that.
That might have been a later model. They probably put in the decomp to cut down on the number of dislocated shoulders. And don't try cranking that hog between your legs.
