Get your Forestry Forum Hats while they last!
Welcome.I know a lot of people on there stack and sticker for air drying. Do you need a kiln?http://www.forestryforum.com/board/index.php/topic,18953.0.html
I build high end furniture, cabinets and doors so yes. I will not work with air dried. Bit me a couple of times, kiln dried is just more stable.
QuoteI build high end furniture, cabinets and doors so yes. I will not work with air dried. Bit me a couple of times, kiln dried is just more stable.Fair enough, but you can build a relatively simple "kiln"with a home dehumidifier and some fans. Take that 12% air dried wood and get it down to a nice stable 8% in a couple of weeks. Doesn't matter exactly how you get the wood dry, you jsut need to get it down to the correct level so it's stable.Ian Because of the Great Lakes and being on the 45th parallel we get crazy swings in temp and humidity. When its -20, we basically have no humidity as it just falls out of the air, and I have seen -52 degrees. In the summer we approach 100% much of the time, with temps gettin up close to 100 at times, so wood stability is a bit more of an issue here than some places.No idea what your weather is like but I have always wanted to chech it out first hand!
