Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Wow, that was dumb...  (Read 2861 times)
Offline EmannVB
« on: December 09, 2010, 04:17:09 pm »
...And I do mean dumb!  The following event could have been far, far worse than it turned out; I'll tell you all of my stupidity in the hope of keeping someone from doing the same thing.
So it's been mighty cold here in southern WV.  My TK B-20 has been covered for the better part of a month, and today being a heat wave at 30, I decided to uncover her and run through a warm up.  All went smoothly as I moved all the hydraulics and motors as my wife and 7 y/o loaded slab wood into a basket (which was very unusual, as the mill is about a 1/4 mile frm the house, and I'm usually alone...).  I had shut off the hydraulics motor, and had the drive motor at idle, with the blade disengaged.  I heard an unusual vibration, and set about finding it's source.  In the process of looking around, I thought it might be the belt vibrating near the pulley.  I put my right hand on the belt to stop the vibe...  well, in doing so, I tensioned the belt and the motor was at idle.  In a split second, my hand was yanked into pulley.  Luckily, at idle, the motor wasn't strong enough to pull my hand (and arm) all the way around.  It was, however strong enough to pull it from the 4 o'clock position to the 6 o'clock position and hold it there.  I reached up and turned off the drive motor, but was unable to pull the drive train back wards and retrieve my hand (and ego).  I yelled for my wife, in my calmest "oh s*it, this could be bad!" voice and had her take the guard off the blade.  When she got it off, I had her pull the wheel backwards and I got my hand out.  The other piece that saved me was that I had on a pair of heavy John Deere work gloves.  They're really thick, with insulation and plastic lining.  Without them, I think I would have lost a good bit of flesh.  As it turned out, I have a very swollen hand that won't be of much use in the near term and a glove that's now shredded.
The lesson here:  Don't be an idiot like I was.  If you're gonna stick your mitts in the mill, make sure it's OFF...EVERY THING!!  I can't tell you how many times I've adjusted the throat plate with the saw running.  No more, lesson (painfully) learned!
~Mark
2006 TK B20, 2005 JD TLB 110, 2007 JD 4520, Stihl MS 390, Husqy 350, 1970 Homelite C72, Husky 22 ton splitter, Kawasaki Brute Force 750, and a King Ranch F350 to haul it all!
Re: Wow, that was dumb...
« Reply #1 on: December 09, 2010, 04:29:55 pm »
Good post, Mark.
We all do dumb stuff now and again.  Thanks for the wake-up call.
Yes, sometimes safety has a steep learning curve.  Thank goodness yours came out OK.
I still look at the end of my finger, every once in a while, to remind me of my lesson.  :D
Offline DanG
« Reply #2 on: December 09, 2010, 04:33:28 pm »
Thanks for the candid report, Mark.  Maybe your confession will keep somebody else from making the same mistake.  We all get away with little mistakes all the time, and are usually only reminded of the danger right after we didn't get away with one. :D  Might not be a bad idea to get an xray to be sure nothing is broken in that hand. ;)
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: December 09, 2010, 04:37:55 pm »
Good post Mark!
Good lesson learned.
Most people don't/won't admit to doing something dumb like that, but we've all (most of us anyway) done something dumb and unsafe!
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline Texas Ranger
  • Texan, by God and by choice.
    • Staples Forestry
« Reply #4 on: December 09, 2010, 04:41:31 pm »
Battle scars are for sharing, in hopes the other guy can duck, jump, just not do the stunt.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #5 on: December 09, 2010, 05:15:58 pm »
Glad that it wasn't worse.  Thanks for another safety reminder.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline WDH
  • April 1998 - August 2008
« Reply #6 on: December 09, 2010, 05:22:43 pm »
I have had my dumb moments too.  Real dumb, in fact.  Thanks for sharing.  I will be a little less dumb tomorrow.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline Slabs
  • It don't get no better than flyin' sawdust
« Reply #7 on: December 09, 2010, 07:48:11 pm »
Hi Emann
I just wanted to check in while the old geezer brigade was in the front.
I have the scars like all and frequietly remember how I got them.  We would like to think that we have learned from the scars and won't repeat the mistakes but old Murphy is always hanging around to bite right there where you sit down.  We're still as likely toward those forgetful moments as we ever were.
Thanks for the reminder.
Slabs  : Offloader, slab and sawdust Mexican, mill mechanic and electrician, general flunky.
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #8 on: December 09, 2010, 08:12:03 pm »
Very glad you're OK.  Things can go either way and we must be thankful when it's only a close call.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   W-M LT40SHDD w/42HP Kubota, Peterson WPF 10-30 with chain slabber. LogRite fetching arch, capstan PortaWinch, W-M CBN sharpener/dual setter. Rens P4000 Metal detector.
Offline Dave_
« Reply #9 on: December 09, 2010, 08:40:01 pm »
I'm a cabinetmaker and have had way too many close calls around my machines.  I have discovered that I never get in harms way when I'm using ALL my thinking.  The moment of inattention can be disasterous.  Now that I've added a 48" circle of death to my life, I try to remember the old mantra from my millwrighting days, "Lock out, tag out, always"
Offline morbid fury
« Reply #10 on: December 09, 2010, 09:02:55 pm »
I have to "hand" it to you , that was close. Just a reminder that it takes a second to do something that can go bad. I can see me doing the exact thing. Thanks for the post. I would much rather read it than live it. Hope you heal quick.
If at first you don`t succed, skydiving is not for you.
Thomas 2411
Husky 266xp
Honda 850 sportsman
Thomas log Arch
Happiness is a fresh pile of sawdust
Offline EmannVB
« Reply #11 on: December 09, 2010, 09:50:24 pm »
So it would seem I have no broken bones  8)  Aside from being mighty swollen and sore I think I'm going to be semi-usable tomorrow.  Gotta build the doors for the barn before Monday as it'll be 9 degrees!  The one things still causing a bit of concern is that I have to feeling in my thumb.  It works just fine, but feels like it has Novacaine in it.  Must have mashed a nerve!
Having recently retired from the Navy, I find that our tradition of reporting our injuries for the benefit of others is worth the embarassment.  And for the record, you guys have been far easier on me than a ready room full of Aviators  :D
Be safe!
Offline Dave_
« Reply #12 on: December 09, 2010, 11:24:44 pm »
...something about people in glass houses throwing stones :D
Offline jdtuttle
  • If it's worth doin, it's worth doin right
« Reply #13 on: December 11, 2010, 08:52:49 am »
Glad your OK & thanks for the post. I had a fall last January while carrying some boards & fell on the ice. I thought I broke some ribs but x-rays were negative. About ten days later my hand started to swell & I couldn't use it at all. Seveal weeks, some xrays & an MRI later they determined the bone was bruised. I never realized it when I fell but I must have landed on my hand. Hopefully the bones in your hand arn't bruised. The Doc said when you bruise a bone it takes about a week for it to show up.
Jim
Have a great day
Offline gator gar
« Reply #14 on: December 12, 2010, 08:49:53 am »
I worked with a welder who, I guess had his mill engaged and decided to grease the roller bearings as they were turning. The blade caught the grease hose, snatched his hand in there and now,he is the proud owner of three fingers and a thumb on one hand. Cut one finger smooth off at the knuckle.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #15 on: December 12, 2010, 10:31:40 am »
thanks for the note of caution.  We all need these wake up calls to remind us to keep our mind on what we are doing.
I was at a farm show once, and watched a man apply belt dressing to the inside of a running belt by hand on a shingle mill.  I put that in my "not smart category".
lots of dull bands and chains
Offline Just Me
« Reply #16 on: December 17, 2010, 07:42:19 am »
 Glad you are ok. I di that same thing with a cement mixer that was running when I was a kid.
 In thirty five years of woodworking I have had some serious injurys. All in all I have cut or mangled five fingers, and cut the same one off twice!
 I never did the same thing twice but seem to always be able to find new ways to do damage. My last one cut off my left index, half of my thumb, and half way into my middle finger. The middle finger and thumb were saved, the index is gone. The index was sown back on before, guess it was just not meant to be.
 People startling me is my big problem, three of my five injuries were being startled when concentrating on the task at hand. In the shop I can lock the door, but on site I have to watch it.
I am much more careful now that I have realized that I am not superman............
Offline weisyboy
  • sawmiller & logger
    • Weiss Sawmilling and Property Maintenance
« Reply #17 on: December 17, 2010, 08:20:24 am »
iv had lots of those times when i think " what the hell was i thinking" most of the time the answer is i wasnt.
glad your ok. dont do it again.
god bless america god save the queen god defend new zealand and thank christ for Australia
www.allausie.com
see a heap of pics here http://www.facebook.com/profile.php?id=100000696669814&sk=photos
Offline backwoods sawyer
  • LT-70 proto-type, Cooks AC-36 with edger
    • Backwoods Custom Milling Inc.
« Reply #18 on: December 18, 2010, 12:38:07 am »
That was a close call!!!
I was working night shift when the sorter operator shut the mill down and sounded the alarm. He was missing the end of his index finger. When he returned to work, I asked him to show me what had happened. It had been a slow night and he had noticed a small hole in the chain guard and had stuck his finger in the hole. These machines will bight and deserve that respect.
100% portable. From our Backwoods to yours....
Offline easymoney
« Reply #19 on: December 18, 2010, 08:52:53 pm »
 now that was funny. i guess he found out what the chain guard was for.
Saw Anywhere!
