Get your Forestry Forum Hats while they last!
There is a lot to learn and I can tell you I learn something new every time. Anybody who tells you they know everything is full of chit.Kevin
Welcome ScottWojoTell us about the tips and materials. Thanks.
You don't have to have a degree in mechanical engineering nor a degree in It tech tech to rework a saw engine .What you need is the tenacity of a wolverine to carry it though .If it works ,fine ,if not so what ,at least you tried .
I'm generally part of that 99.9%. However, in my case, I was having trouble with my 2152 overheating. It would run just fine for a full day of felling (generally time to cool off between cuts, or lighter loads when limbing). When bucking hardwood for firewood, it would run OK for a couple hours, then stall and have trouble starting again unless I let it cool down first.John Mc
Quote from: John Mc on November 22, 2010, 01:07:51 pmI'm generally part of that 99.9%. However, in my case, I was having trouble with my 2152 overheating. It would run just fine for a full day of felling (generally time to cool off between cuts, or lighter loads when limbing). When bucking hardwood for firewood, it would run OK for a couple hours, then stall and have trouble starting again unless I let it cool down first.John McWhat causes this is indeed the cat muffler. In sustained use, the heat from the cat will gradually increase the crankcase temp to the point where the saw will simply not run right due to fuel atomization issues. Take it to a shop, and gee, there's nothing wrong with it. Back to the wood pile and the problem returns. I stopped selling 359's and 2159's due to this problem, and this is why it's so important to get a non-cat 346 when you buy one.
