Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Seperating water from hydraulic fluid  (Read 5124 times)
Offline Hilltop366
Re: Seperating water from hydraulic fluid
« Reply #20 on: November 20, 2010, 09:03:31 pm »
I've drained the hyd oil and changed the filters on the backhoe twice now as well as clean the pick up screen and it seems to be working a bit better. According to the specs only a third of the oil will drain durring oil changes meaning that two thirds of the contaminated oil is still in the cylinders. This is starting to get a bit expensive.
Woodbowl after having a 1979 backhoe for almost 20 years (bought in 88) I think you chose the right words "starting to get expensive", I must say though that if I had gave or thrown it away a few years ago when I sold it the old thing really didn't owe me a dime for the amount of work we had done with it... just got tired of working on it. I always told people that thought it would be handy to have an old backhoe that I could go out and spend $1000 any time, and do it again next month.
 The pump on mine is at the front of the engine. I had replaced the main hyd. output line and was waiting for someone to weld the frame which is the hyd. reservoir.
Sprucebunny sound like you might have a Case?
Banjo picker that is very good advise, I might add that some of the parts a very heavy so don't get directly under them when removing them and put a tie down or rope on heavy parts when removing or installing them just incase the fall.
Offline Dangerous_Dan
  • Poor planning on your part does not constitute an EMERGENCY on mine.
« Reply #21 on: November 22, 2010, 06:10:11 pm »
Woodbowl, here's the pics you requested via PM of the homemade centrifuge.
I figured I would just post them here so everyone can see them and copy my setup.
Not pictured is the holding tank for the liquid. It's best to heat oil before running it through. The thinner it is the more crap will come out in less time.
The liquid is gravity feed and the valve allows you to set the flow. The lower the flow, the cleaner the oil and the more time it will take.
The spinning rotor is made from a modified Ford sepentine style power steering pulley threaded on a standard 3450 pump motor. The stand is homemade from some angle iron. To clean the crap out of the centrifuge unscrew the rotor and wipe out the goo. Screw it back on and your ready to go agian.
DD
First you make it work, then you trick it out!
Offline rbarshaw
  • Someday
« Reply #22 on: November 22, 2010, 06:35:54 pm »
My Grandfather had a cream seperator that worked on the same principle, I just wonder if someone was to use one if it would work.
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
Offline woodbowl
  • Making old fashion, oblong dough bowls, sure is a lot of fun
« Reply #23 on: November 22, 2010, 11:30:39 pm »
Thanks for the pics Dan. I hadn't thought of using a pully. I just took a look at the power steering pulleys on all my vehicles. They seem to have the shape, but not as good as yours.
Lets see if I understand how this works. The stream enters the center and is slung outward against the pully wall. The heavy crud clings to the wall and the lighter oil is to the inside. As the pully wall is filled the light oil climbs the wall and slings out over the top and into the pan to be drained off.
I can't tell from the pic, but is there a lip on the inside of the pully to keep the crud from spilling out with the clean oil? What volume can it handle per hour?
Full time custom sawing at the customers site since 1995.  Added homemade hydraulics to a 1988 manual WoodMizer LT40.
Offline Al_Smith
« Reply #24 on: November 24, 2010, 06:47:47 pm »
     Both the Main and Vital systems stopped working while they were on patrol.  They had to surface and wait for an ocean going tug to go get them and bring them into port.  What a mess!  All due to them not taking care of their stored oil.  When the main system needed oil they transferred contaminated oil from storage and the algae blocked all the filters and many of the electro-hydraulic control valves.
CLEAN YOUR SYSTEMS!
Bruce
--and I well imagine they had a change of command and no doubt the engineering officer could kiss his career goodbye over that one .--BTW I spent 4 years on the boats ,fast attacks  ,one boomer ,one diesel --- Norfolk,New London ,Rota .
« Reply #25 on: November 24, 2010, 07:59:25 pm »
I welded a plate to the open end of the pulley and bored a hole in it with a lathe. In the pic, the oil is stream is running through this hole.
The pulley can trap 1-2 cups of crud.
I was running about 5 gallons of WVO in 1 hour and getting 1 cup or so of crud and goo.
The slower you run the oil through it, the cleaner it will be.
DD
Offline Wintergreen Mountain
« Reply #26 on: November 24, 2010, 09:24:22 pm »
     woodbowl,
I would find a good clean 55gal barrel, drain all the oil you can out of the macine. Put it in the barrel. Lay it on it's side in a dry warm place with the small bugne down at the bottom and up so you can get a pail under it later without disturbing it much. Get NEW oil and put it in the machine.
    Let it set for about 2 months. without disturbing it, take the small bunge loose and drain off the settled water and dirt. Tip the barrel up to get all the water you can out. When just oil comes out, stop draining. I have reclaimed hundreds of gallons of oil this way. Once you have most of the water drained out, strain it and put it in pails for later use. If the oil doesn't clear up it has addatives in it.
    Leon
1920 Ford 4x4 tractor, forks & bucket.      2010  36" Turner Mills band mill.      Cat D3C crawler dozer.
Offline Al_Smith
« Reply #27 on: November 25, 2010, 12:26:35 am »
Well now gents and ladys .You can cheap out and use contaminated oil  but just like the Ampco man pay me now or pay me later.Use that water logged oil for wood preservative or burn it,do not attempt it in a usable hydraulic system .Don't be penny wise and pound foolish now .
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #28 on: November 25, 2010, 09:22:26 am »
I had never thought about reusing it.  Some of these methods sound pretty good, but I guess I am just too cheap to try it .   ;)  Tim
Cooks AC 36--Prentice 210C--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #29 on: November 25, 2010, 09:21:27 pm »
, It just burns a lot better with the water removed .  ;)
   Marcel
Offline Al_Smith
« Reply #30 on: November 26, 2010, 06:13:46 am »
Well there is some merit to that .I've got two buddies with waste oil burners and they do very well .One owns a welding shop the other has a 60 by 95 building with about a quarter  million bucks worth of Camaros and Vets in it .
Offline Holmes
  • 1840 house
« Reply #31 on: November 26, 2010, 08:19:59 am »
        Would that be 4 cars or 5? :)
Think like a farmer.
Offline Al_Smith
« Reply #32 on: November 26, 2010, 04:12:38 pm »
 :D I think the number varies from time to time . There were a couple Yanko or who ever that  Camero wizz kid is in his shop .Long story .
Point being though with the oil burner and essentually free oil he can maintain his temp and humidity to preserve the investment .Makes more sense to me rather than use contamenated oil and take the chance of ruining a piece of equipment but that's not my call ---just my 2 cents worth . ;D
The old not detergent oils kept things in suspension but modern oils do not .It won't "settle" like that 50 year old stuff .Once hydraulic oil becomes "homoginized " with water I'm not so sure you can get it out or not .
Offline woodbowl
« Reply #33 on: November 28, 2010, 10:02:41 pm »
I've done quite a bit of reading lately about cleaning oil with a centrifuge. Most of it seems to be about wvo. What I haven't found is a small home operation that cleans up their own motor oil to reuse in their personal vehicles. What happens when motor oil gets really hot and burns, and is put through a homemade centrifuge to be cleaned up to within 1 micron? Is the viscosity affected or can it be continually cleaned and reused? Are we talking about the same quality recycled oil that is sold to the public?
If it does that good a job, fish grease should be a really big savings.
« Reply #34 on: November 29, 2010, 03:41:54 pm »
When I was younger, recycled oil was sold in the filling stations to top off your crankcase oil.  It must have been sold to them as bulk, because, at the pump, it was delivered in quart mason jars with a cone shaped metal lid that they used for a pouring spout.  You could mix non-detergent with detergent oils, so I guess that the recycled oil kept its viscosity.
You could also buy "Generic" canned oils.  They were usually in a stand next to the pump and were in cans with plain green or blue labels with white lettered "OIL" printed on the side.  I was always told that it was reclaimed and the equivalent to 30W, since it had no other markings.  30W was good for pretty much everything back then, and many mechanics didn't care for Detergent oils because you couldn't mix the oils if you were on the road.  It limited you to one brand of oil/gasoline.  'Course we were all very brand dependent anyway.  My family bought Gulf until Philips 66 showed up, then it was tried because of the claim of better mileage.
It seems to me that heat would be a good way to get rid of water in oil.  Water doesn't stay liquid above 212°.  If you turn it to steam, it has to go somewhere.
I  have always had a probem with water in my Little Blue Tractor (Ford 1910, 1985 model).  The oil in the transmission is hydraulic oil and feeds all of the applications of the tractor.  Within a short time, I noticed that it was white.  The Dealer told me that it was water from condensation and that all of these tractors do it.  They had complained to Ford and were told that it didn't hurt anything.  so, for the last 25 years, I have not paid any attention to it. Now my 3 point hitch doesn't hold good and my frontend loader won't pick up what it should.  The filter is new, so I'm thinking that the valves under the seat may need attention.  I've never been into them before and hate to screw something up.  It's not the pump because strength is only a problem intermittently.    The engine has to be run awhile before good oil flow happens so I guess I need to find someone who knows what is going on.  Unfortunately, Duval County Florida is lacking in that kind of expertise deciding that retail malls are more important than farms and mechanics.
Anyway, I degress.   I've been told that oil is a lot more durable than we give it credit for being.  If it weren't for the marketing efforts of big oil companies, we could still be using reclaimed oil economically and with good results.
Offline pineywoods
« Reply #35 on: November 29, 2010, 09:51:13 pm »
Don't see why heat wouldn't do the job. Water boils at 212 deg F at sea level. Oil doesn't start to break down till around 300 deg F so keeping a batch at a steady 250 should get rid of the water. Maybe a turkey fryer would do 5 gallons or so ?
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline submarinesailor
  • LT15, F250 SD 6.0L diesel, and a wife of 38 yrs
« Reply #36 on: November 30, 2010, 05:39:14 am »
« Reply #37 on: November 30, 2010, 05:48:19 am »
Here is an other good article on seperating water from oil and why you should do it:  http://www.machinerylubrication.com/Read/503/water-oil-removal.
I had forgotten about the effects that water has on the additive package in the oils.  And believe in or not, additives can be very important to your oil.
Bruce
Offline Bandmill Bandit
« Reply #38 on: December 10, 2010, 07:21:00 pm »
Trying to reclaim contaminated Hydraulic oil is not being cheap or thrifty. That is just plain irresponsible.
I have wrenched on both the Green stuff and the Red stuff and the Cat stuff and all have their pros and cons.
Regular swap out of Hydraulic fluids is the best preventive maintenance you can give your valuable equipment. Most hydraulic fluids will have an expect life of about 200 to 500 hours use time max and that is dependant on your care or lack there of and the operating conditions.
IT is very easy to blow 8000 to 10000 to repair a hydraulic system that was damaged through just plain bad maintenance practices.
8000 bucks will buy more hydraulic fluid than you can use in the life time of a good piece of a equipment but it will never put your equipment back to OEM quality. Only good maintenance will prolong that time frame as far as possible.
Heating Hydraulic fluid with out proper equipment to establish measure and maintain the correct temperature is a good way to alter the molecular structure which can have very undesirable side effects in your machine.
It is possible to set up a system to clean the oil but for the price why bother. New oil is not that expensive in the long run.
There are still a few reclaimers in Canada. Not sure if the product ends up back in the retail oil products market but no reason it shouldn't as far as i know.
If you ain't livin on the edge you are takin up way to much room. Of course at my age if I get too close to that edge any more theres a good chance I may fall off.
Saw Anywhere!
