Get your Forestry Forum Hats while they last!
Have you blead the bleeder fitting on top of the axle housing on each axle?
Inboard off the axle housing ,actualy on the carrier case is a bleeder that bleeds the brake pistons, where the axle housing bolts to the diff. case on the top side for each axle, these are not greese fittings and were on every J.D. I ever worked on.
