Get your Forestry Forum Hats while they last!
When I was living in Alaska, I built a wannigan (addition on a mobile home), made it from 6" (between the slabbed faces), logs, that I bought from a miller in Fairbanks for cheap
I had been thinking of trying to find a use for smaller diameter pines. I then got the idea that instead of leaving them in the woods, mill two sides off them, peel the bark and put them aside. Of course they would have to be big enough, but my thinking was that eventually I would have enough small diameter logs with 2 flat faces, to make a primitive hunting cabin in the woods or something similar.
One secret to milling small logs is good clamping. Small logs need to be clamped more securely than large logs, as they don't have the weight to help resist the blade force and in the worse situations, can fly loose and wreck your blade, or worse. This event can also wreck your sense of well being for a while too.
