Get your Forestry Forum Hats while they last!
Here is something I wrote up and put in the Knowlege Base about our roto-phase setup..http://www.forestryforum.com/cgi-bin/tips/tips.cgi?display:1048263552-19768.txt(Image hidden from quote, click to view.)Probably my best idea was to install a "distribution block". That's the big gray box in the upper left. That's where I ran the converted 3ph to. I've since added a number of 3ph machines and have only had to come to this box to connect in.BTW, I'd suggest a much larger phase converter. I've been told you need 2X hp converter to start a motor. Plus, you'll want to add more stuff once you have 3ph power. If I were to do it over, I'd run a 100hp.
(Image hidden from quote, click to view.)The gadget on the right is a distribution block. Used at a different point in the converter than what Bibby menitioned.Really great for power management. Expensive new but you can pick em up on eBay used, in perfect condition, and best of all cheap.
